Question about Dryers
Dryer motor fan stripped and broken while trying to get it off
While trying to replace dryer motor, the blower fan plastic nut broke into pieces before I could get motor loose. I have to get motor fan off to replace the dryer motor. I will need new motor fan too. Any other way to get fan off without having to start breaking it away in pieces?
Buffalo12980
  • 625 Answers
SOURCE: Loose drum support felt
you could try using "Permatex" hi-tack adhesive.  you need to remove the door where the bearings are first.
Posted on Oct 14, 2007
SOURCE: Can't remove motor from dryer
I access the motor to replace it but can't seperate it from the fan wheel.
Posted on Jan 09, 2008
SOURCE: replacing blower wheel
make sure you turn the nut clockwise to loosen it.
(backward threading)
Posted on Jan 29, 2008
  • 1073 Answers
SOURCE: i am trying to remove
check the end threads of the new motor are the not left hand threaded, if so you are tighhtning turn the oppisite direction
btw you may have to replace the blower if it cracked the blower when the plasitc came off might have to use vise grips to ge it off
Posted on Apr 26, 2008
duby1990
  • 367 Answers
SOURCE: Removing blower fan from motor on Kenmore Elite 90 Series Dryer
Hold the shaft of the motor while you turn it. it may also have left hand threads.
Posted on Nov 20, 2008
The bottom blower fan (blows hot air out) on my Haier room air conditioner broke and broken plastic parts were inside. I took the broken pieces out and now the fan motor wont turn on. Could motor have...
you can ohm the motor out. Go between each wire and see if you get an ohms reading you should have a reading if you don't then you have a winding burnt out.
Aug 21, 2014 | Heating & Cooling
How do I remove broken fan
The fan is reversed threaded. Lefty tighty righty loosey. To get a stubborn blade off without harming the motor use a adjustable wrench to connect to the flat portion of motor shaft inside the dryer and place the end of the wrench to the left on the floor. Jam a Large flat file in between the blower wheel at the 3 o'clock position. Use downward force with a large hammer to knock the blower loose. If it still will not budge hit the center of the plastic till the blower pieces are removed so that you can get over to an anvil with the motor. Lay the motor shaft on the anvil and bang on the pot metal left over from the plastic till it breaks. 2 or 3 good whacks with a big ball peen hammer should do the trick. You want to keep in mind the motor does not needs to be wrangled with but you still must get the remainder of the old blade off there.
May 26, 2013 | Whirlpool LER5636P Electric Dryer
Hi, my 1998 dodge durango front AC/Heater blower motor run on and off, after the fan shuts down and stops running if I reah under the dash and hit the plastic fan housing it will start-up running but it...
If you can hit on the blower motor housing and the motor starts, your brushes on the motor are bad and the blower motor needs to be replaced. Used tested unit $30.00 at a junkyard. New rebuild $54.00.
Many posts have stated that the dash must be removed to replace the blower motor. It can be done without removing the dash. I know as I replaced the blower motor on my kids 99 Durango last night but it took about 4 hours. Now that I know how to do it, it would estimate 2 hours.
Remove glove box by opening glove box all the way. Press inward on the both sides of the glove box to allow the rubber stops to clear the catches and lower the box The two outer hinges (plastic) will come off by slightly twisting the glove box upward leaving only the center hinge (plastic) in place. Reach in and push down on the hinge to pull out glove box. Set aside.
Remove side trim panel by pulling back carpet and remove one Phillips screw. Remove panel by pulling back on upper portion to remove clip from frame, then slide forward to remove from lower plastic trim.
Use 1/4" nut driver or socket to remove two screws holding vacuum canister on lower right side of blower shroud. Remove two vacuum hoses noting which hose goes to which side of the vacuum canister (both were green in color on my Durango). Disconnect connecting rod from vacuum canister to vent control by removing lock washer (you may be able to get away with not removing the rod, but the plastic "fin" may break if you stress it while removing the blower shroud.
Use 5/16 nut drivers/sockets with extensions to remove the blower shroud hex bolts. The hex bolts are located in several areas around the shroud (use your finger to follow shroud edges to locate all 8). Some of the hex bolts are very tricky and may require odd positioning of your body to locate and remove them.. I also put several extensions to use in order to reach the various hex bolts. Once the hex bolts are removed, pull the plastic blower shroud down exposing the blower motor squirrel cage.
Remove two of three hex nuts holding blower motor in place. Loosen the third one and the blower motor should come free. I was not able to remove the squirrel cage from the old motor so I broke the squirrel cage allowing me to expose the wire harness and grommet that went through the back of the shroud.
Feeding the wire harness back through the assembled wall appeared to be a real challenge, so I cut the green and black wires at the motor for splicing into the new motor later. Remove the motor and broken squirrel cage and throw the dam thing away.
Remove squirrel cage from new motor by removing retention clip with a pliers. Pull off the squirrel cage carefully by applying WD40 (or other lubricant) to the shaft. You may have to place two large screw drivers or other pry bars underneath the squirrel cage equally across the underside of the squirrel cage slowly prying up the cage. I accomplished this with a helper to hold the motor in place to allow equal pressure from both pry bars.
Cut green and black wires on new motor leaving enough wire to work in the tight area of the motor housing. Strip wires from old harness and new motor and apply **** splices for green to green and black to black. Add electrical tape for extra mechanical strength and insulation.
Place new motor into housing and secure the three mounting hex nuts. Turn on key and run blower to make sure it works. Install squirrel cage and retaining clip on motor shaft. Run again to make sure it works.
Install the balance of the items in the reverse order you removed them.
Now on to replace the rear wiper motor on the same Durango. Junkyard parts $54.00. Time: Unknown?
Jul 31, 2011 | 1999 Dodge Durango
1990 Mercedes 300E.How to Reaplase Blower Motor?
This is a 124 chassis model.The blower motor is under the cowling just in front of the windshield.You will need to remove the plastic pieces in front of the windshield and the wiper transmission.It will have squirrel cage fans at each end.If you are not experienced with removing these fans,use extreme care,because plastic gets brittle with heat and age.You can use a hairdryer to warm to plastic hub for easier removal.When tapping the motor shaft free of the cage,keep it evenly supported.Make sure not to drive the cages onto the new motor shaft too far.They will contact the housing.Replace broken fans-they vibrate badly.Blower motors with new fans installed are readily available for extra bucks.
Jul 04, 2011 | 1993 Mercedes-Benz 190
Noise from lower blower or compressor
pieces broke from condenser cooling fan,can i get new wheel or blower
Aug 16, 2009 | Royal Sovereign ARP-3012 Air Conditioner
Can't remove dryer blower wheel
I would start by taking off the top and checking the belt to see if part of it tore and is hitting the inside of the cabinet. I have not found a real good way to get the blowers out without having to break them sometimes. the part of the blower that you have to hold is access through the front behind the motor. problem is when you turn the motor shaft, the wrench strips out on the blower, then you have to break them, but unless you need a new motor, it should not have to come off.
Jan 27, 2009 | Whirlpool Dryers
you need to pretty much disassemble the whole machine. the top cover comes off, the front panel with door comes off. the drum lifts out to access the motor as it is bolted to the floor.
Nov 29, 2007 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
