Hotpoint wd860 filter
Wher is the filter located and how can i get to clean it?
  • vikki72 Feb 26, 2009
    I have already had the engineer out twice (machine still under warranty) as the filter gets blocked and is not easy to access. He advised that I call every 3 months rather than wait for it to get blocked again. With 3 cats creating "fluff" it's not easy to stop it getting blocked. On my old Zanussi the fluff filter was at the front of the machine and could be checked/cleared after each wash.
  • Washing Mach... Master
  • 3,463 Answers
Access to the filter is by removing the rear lower panel of washer.
Locate the large black hose on right and remove clip and hose. watch out for water in the hose.
Remove filter and clean Refit filter and hose, securely fasten the hose and test for leaks.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
  • ultrakat Feb 20, 2011
    We were in trouble and had no idea.
    This advise helped us beautifully!!
    Thank you very much!
Falshing f05 hotpoint wdf 740
The fault is associated with drain out (pump blocked or restricted in some way). Try to clean it or contact Hotpoint support
Sep 25, 2013 | Hotpoint Washing Machines
How doI get the clips off the Hose
Slide it to the side of the grip teeth this aids removal..
Apr 19, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima wd860; My washing keeps coming out smelling musty even though I use conditioner regularly. Is ther a filter I need to clean out. Thanks
you need to clean the draw and the inside of the draw and clean the rubber door seal all way round when you done that use a washer clean detergent whitch should be at a super market. and run it at 90 or 95 temp cottons wash it should stop the smell beacause dirt is buliding up so a good clean should stop it.hope this helps.
Sep 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
MY HOTPOINT WD860 WASHING ACHINE HAS FLASHED F 05 DOES ANYONE KNOW THIS PROBLEM CODE.THANKS
F05 indicates that pressure switch is jammed on full.
Remove lower rear panel of washer, and locate and remove large black hose on bottom of drum, remove and clean filter inside of hose.
Please rate my solution.
Thanks.
Aug 30, 2009 | Washing Machines
Hotpint washer will not spin
F 05 IS A PUMPING PROBLEM CHECK IF FILTER IS AT BOTTOM FRONT R H S.CLEAN OUT AFTER EMPTYING.IF NOT AT FRONT IT IS LOCATED AT BACK OF MACHINE IN PANEL AT BOTTOM . THE FILTER IS IN THE BLACK HOSE COMING FROM TUB. ++++ REMOVE PLUG BEFORE DOING ANY OF ABOVE +++++
Mar 23, 2009 | Hotpoint Ultima WF860 Front Load Washer
Have hotpoint wd860 washer/dryer. Message fy05 appears, any ideas - won't spin
This code relates to a drainage problem and will probably be a blocked filter. Check behind the kick plate at bottom of machine for screw off type filter, if not there it will be in the large pipe from drum to pump at the drum end.
Thankyou for using Fixya.
Jan 22, 2009 | Washing Machines
F7 fault code on Hotpoint WD860
Fault code F7 is a heater relay fault
Sep 25, 2008 | Washing Machines
Wash doctor
Filter is to be found in the sump hose which is located in the large hose at the rear of m/c.
Remove hose from bottom of tub, the filter is in there.
You will need to remove the lower back panel.
Sep 04, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Ultima Washer/Dryer Supersilent....
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
2,571 people viewed this question
Top Washing Machines Experts
