Question about Remington S6500 Sleek and Curl Ceramic Pearl Multi styler Hair Straightener, 1 Inch
So how do I keep my Remington pearl straightner from turning off
3 Suggested Answers
SOURCE: i have just brought a
you just need to change the fuse in the plug - it's a little capsule inside the plug.
Posted on Dec 30, 2010
besthomeo
  • 108 Answers
SOURCE: I lost my directions for
you should use towel then use it. Then you take the right position of your hair . This is do you some days after 1 week you get you target
Posted on Jul 04, 2011
Why do my straighteners keep turning off
I had the same problem. The solution was quite simple actually. I took the iron apart. The problem was that one wire got loose. I soldered it back where it belongs and now the iron works again.
CAUTION! This procedure should be done by a qualified electrician only!
Jul 14, 2014 | Remington S9500 Pearl Hair Straightener
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Remington pearl plates won't heat with blue light?
1) you have to test the power cord for broken or fault with VOM
2) inside there are thermal fuse, test it and replace with VOM
3) test the heating element for open and replace, and test for ground
4) test the thermostat, and adjust it.
God bless you
Jul 22, 2012 | Remington T-Studio Pearl Ceramic 1" Slim...
Iv got the baby blue remington shine therapy hair straighteners but i keep hitting the heat button i try to lower my hand down th straightner but its not very comfy how can i avoid hitting the heat button....
I realize this post is a few years old but I'll answer anyway in case someone else needs help. If you press and hold the - (minus) button it will lock the temp and power button and won't unlock until you press and hold the - button again.
Jul 21, 2011 | Remington S9951 Shine Therapy Frizz...
I lost my directions for my remington wet 2 straightner.
Jun 27, 2011 | Remington S7100a Wet 2 Straight 1 Inch...
Is there a manual or step by step guide to take apart to re-wire a remington S1005 as my daughter has managed to split a wire by coiling it around the straightners when not in use...Everything works as...
dont take it apart just sauder the wires together and wrap with electrical tap should be good to go just make sure u sauder the same color wires together such as red to red and black to black etc
Oct 19, 2017 | Remington S6500 Sleek and Curl Ceramic...
Why does it keep turning off once it reaches the temperture i want it on??
The hair straightener has an internal thermostat which prevents it from over heating. This kicks in when it reaches hte correct temperature, and turns the heating element back on when the plates start to cool down.
Jan 15, 2011 | Remington S6500 Sleek and Curl Ceramic...
Remington S6500 Sleek and Curl Ceramic Pearl Multi styler Hair Straightener, 1 Inch Logo
26 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
