Question about Dryers
Need to fix start button on LG DLG2102W dryer
All buttons works on the dryer panel light up and work except for the start button. It doesn't light up and the dryer won't start. Is this something that I can fix myself?
Illeagle
  • 525 Answers
SOURCE: I have a Maytag Neptune
This is your complaint;
"I have a Maytag Neptune MDE4000AYW Dryer. The internal light is on but the control panel will not start the dryer. The breaker did not trip, i have full electricity to the dryer. My settings work but will not preform when i press the start button. Is this an internal electrical problem? Can i fix this myself?"
Thank you for providing a valid make and model number!
Tip: A volt-ohm meter is a valuable tool for diagnosing problems.
My Solution:
!. Sometimes a breaker will only trip 1 side of the 2 sided breaker. Reset the breaker by flipping it off then back on to remove any doubt!
Note: This is not 100% positive, as a breaker can fail on 1/2 the sides, so you will need a meter to test voltage, if you have ruled all else out.
2. Sometimes a thermal fuse in the dryer will open due to a venting issue. The fuse is mounted on the blower housing
or on the element tube. See links for part diagram: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516650&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1660&PPStack=1
See this link for diassembly procedures:
http://www.repairclinic.com/0100_18.asp
Inspect your vent thouroughly for obstructions. Also, inspect your lint filter if you use fabric sheets, by holding the filter flat under running water. If the water beads up and does not strain through the filter screen, replace the filter and avoid using fabric sheets.
3. The door switch may have failed, see link for part diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46718, See item no.6.
4.Wiring: The wiring at the dryer terminal block may have burned up. See link for diagram:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516193&PPStack=1
5. Push to start switch failure. See link below:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1033496&PPStack=1
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 16, 2008
SOURCE: Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Posted on Sep 27, 2010
heatman101
  • 43501 Answers
SOURCE: when we push the button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 20, 2011
heatman101
  • 43501 Answers
SOURCE: My Kenmore dryer won't stay
heatman101
Posted on Jun 02, 2011
Testimonial: "you have been alot of help now I need to go home and double check the items you have listed to see if I can get my dryer to work"
  • 160 Answers
SOURCE: My LG gas dryer Model#DLG2102W is not heating up.
Its most likely in your ignitor or valve and flame sensor. You can test the ignitor to see if it glows and sends amp signal to valves to open them.
To see the diagram and parts follow this link. Parts are # M110, M160, M240. Also check M220 to see if its still good.
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Dryer-Parts/Model-DLG2102W/3204/0151200/F0906014/00003?blt=06&prst=0&shdMod=DLG2102W
If you need further assistance please feel free to contact.
Posted on Jul 27, 2011
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
May tag mce8000ayw start button doesn't work.
no you need to replace the hole thing whach is called Console W/membrane Pad part number 31001658
it may cost about 200.00
Jan 30, 2013 | Dryers
Aeq6700fso dryer dryness button won't change the
E68 is a stuck button on th control panel
Nov 06, 2012 | Dryers
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 | LG WM2016C
Replaced starter button and it worked for awhile. Now it doesn't. If I keep it pressed, dryer runs. If I release, it stops. wedged screwdriver beneath button and that works
The bad news is your switch spring isn't working or is broken. The good news is that you already know how to replace the switch.
Sep 04, 2011 | LG DLE2532W Electric Dryer
My LG gas dryer Model#DLG2102W is not heating up. I cleaned out all the vents, but it is still not working. Not sure how to fix it.
Jul 27, 2011 | LG Dryers
Only a few buttons on my key panel work, example the start/ clear button does not work, a few numbers do work. I think its from condensation. How can I dry this out? Can I use a hair dryer?
Yes you can use a hair dryer but the power should be off so that you don't short it out any more than it already is. Most likely the keypad has been ruined and will need replaced., Once these go bad there is no fix except to replace the keypad.
Apr 23, 2011 | LG LMVM2055 Convection/Microwave Oven
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
