Need replacement carbon to repair vintage carbon microphone
Wish to purchase special carbon used in vintage microphones
SOURCE: No Sound Coming out my Microphone
This same thing happened to me. All I did was plug the mic into my keyboard, turned the mic volume to max, and turned the mic on. Then, I grabbed the part of the mic where the cord goes in, and started turning it. I turned it left and started hearing noise come out of the mic. I kept on doing this, until sound came out of the mic. I did this, and now the mic works again. Hope this helps!
Posted on Dec 22, 2008
  • 65 Answers
SOURCE: Disassemble Singstar Microphone
I have the book you are asking for but i am looking at it and it does not say any thing about that but I do have phone numbers to call in order to get help,1800-345-7669 Technical support line, and questions regarding PlayStation2
m-sat 6am-8pm and sunday 7am-6:30pm pacific standard time. this # is for SingStar"80's"
good luck
nikki2913
Posted on Dec 29, 2008
  • 919 Answers
SOURCE: Hand microphone for DT 100 does not work. Need replacement mic
MR-9 Microphone for DT-1000
The MR-9 Microphone allows direct dictating to the DT-1000 Transcriber and also permits you to control the playback functions remotely. Remote playback functions include Listen, Fast Forward, Rewind, and Stop. Cord extends to approximately 6 feet.
http://www.olympusamerica.com/cpg_section/cpg_audio_acc.asp?val1=1&accessory=76
Posted on Jan 30, 2009
  • 31 Answers
SOURCE: cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Posted on Mar 17, 2009
  • 31 Answers
SOURCE: microphone
Inspect your computer to see if has a hole somewhere that might look like a microphone. If you want to find out for sure open up your windows sound recorder from Start - Program - Accesories - Entertainment. Hit the record button and talk or yell something if you would like. You should see recorded sound wave in the middle of your sound recorder. If you do not see the recorded waves this might mean that your microphone is turned off. To turn it on just Double click on the little speaker icon on your taskbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure the microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder and try to record again. If this does not work you probably do not have a built in microphone. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
I have a compaq 7500. Can you tell me where the microphone connection is. Also can microphones for this model still be purchased ?
This monitor doesn't have a speaker or microphone jack available on it. https://h10025.www1.hp.com/ewfrf/wc/document?docname=c00665774&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=313889
These ports will be located on your PC generally on the back. The microphone port will be either red or salmon color and typically have a picture of a microphone by it. Also microphones use a standard port for many many years and any will work just fine typically with no special software required.
Comment back with the model of your computer and I can help you locate the port.
Aug 23, 2011 | Compaq CV 7500 17" CRT Monitor
Through wear and too much handling the wire detached from the microphone. What now?
UNLESS YOU HAVE EXPERIENCE IN REPAIRING THESE DEVICES, YOU SHOULD TAKE IT TO A MUSIC STORE SERVICE DEPARTMENT THAT SPECIALIZES IN SUCH UNITS. REPAIRING THESE REQUIRES A HIGH LEVEL OF MANUAL DEXTERITY AND SOLDERING OF DELICATE WIRING.
Oct 07, 2010 | Sony ECM-44B Lavaliere Microphone...
How to wire an Altec 6369A Microphone
This was the only Altec mike I could find:http://www.altecpro.com/pdfs/vintage/SpeakerAndMics/mics/D91P%20Microphone.pdf It might resemble what you have.You might also try contacting someone here:http://www.altecpro.com/products/vintage/index.htm#mics Let me know if this helps.
Nov 26, 2009 | Altec Lansing Audio Players & Recorders
Ds lite microphone.
Are you sure the game you are using the game is mic compatable. If it is here are some tips you can use to
Nintendo DS - Microphone not responding properly
Not all games use the Nintendo DSs built-in microphone. Consult the instruction manual of the game you are playing to be sure the game uses the microphone feature.
Specific games:
  • Need assistance with the voice recognition feature of Brain Age? Click here to read some tips we've come up with.
  • For help communicating with your dog in Nintendogs, click here for help.
  • Playing Metroid Prime Hunters on the Nintendo Wi-Fi Connection, and have questions or issues with Voice Chat? If so, please click here.
  • Playing Pokémon Pearl or Pokémon Diamond on the Nintendo Wi-Fi Connection, and have questions or issues with Voice Chat? If so, please click here.
  • Playing Mystery Case Files: MillionHeir and having issues with the microphone? If so, click here for assistance.
If you are still experiencing problems with the microphone, your system will need to be repaired. Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty. To begin the repair process, we will need to gather some information from you.
Please click 'Continue' if you wish to set up an online repair order. We will walk you through the process step by step
Mar 08, 2009 | Nintendo DS Lite Console
Does the SE Mini use a standard cable or is there a special cable needed for use in an amp or computer?
you'll need an xlr (male) to xlr (female) to use the microphone with 48v phantom power (from a preamp). phantom power dosnt work with an xlr to jack, only both xlr.
Apr 22, 2008 | SE Electronics SE MINI Microphone
Shure 55sh series 2 mic repair
Hi, I actually rebuild these mics and upgrade them. I'm an expert in the vintage 55's of all era's and the newer. If you are just looking to go back with the stock element of a 55sh2, or looking to upgrade your 55 vintage or new, with a SM58 a Beta 58, or a 87 Beta, I do all of that. All repaires from Hard mounted XLRs, screens, to polishing the surface back to new, or upgrade kits that you can put in yourself with my pictured instructions. Check out my web page at Mutantmics.com or google search Mutant Mics or conatct me directly at whoizitcc69@aol.com
Mar 21, 2008 | Shure Beta 58A Professional Microphone
Microphone
maby on ebay u can find that such a rare mic
Jan 06, 2008 | Shure MICROPHONE Microphone
115 people viewed this question
 Grubhead
Grubhead
