Question about Denon DHT500SD System
Denon 500SD dvd wont play
How do I clean the optical pickup assembly lens?
  • 2,071 Answers
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
hope this may help;
DON'T FORGET TO RATE;
Regards,
VOTIT
Posted on Jan 11, 2009
  • 57 Answers
Open the cover of your dvd player,then get your hair dryer and turn on the hair dryer and clean module board.after that get some 1pc of cotton buds try to clean gently the lens 3 to 5 times.then returned the cover .and turn the unit.
i hope it will work.
kira_ryuk@yahoo.com
  • 827 Answers
You use a Lens Cleaner such as those advertised on this eBay link:
http://shop.ebay.co.uk/items/_W0QQ_nkwZdvdQ20lensQ20cleanerQQ_armrsZ1QQ_fromZR40QQ_mdoZ
Hope this helps
Chris (ziraffa)
Panosonic vcr and dvd when turned on says error
Clean the optical pickup lens, by inserting an lens cleaning disc in to the device, and play it. If this do not help you, replace the optical pickup unit.
Jun 06, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
DAEWOO/DVN8100N / After you put dvd in slot to start the play process , it will not load the dvd. it will close, start, stop ,( no disk) in display window. what is the fix?
Clean its optical pickup lens. Insert a lens cleaning disc into the machine, and play it. It will clean the optical lens automatically. If this do not help you, the optical pickup unit should be replaced.
May 27, 2012 | Televison & Video
Denon dvd 1730 plays no cds
It is likely a issue with the optical pickup in the unit or the unit needs cleaning (not likely but possible)
Apr 08, 2012 | Televison & Video
My handheld dvd player isn't reading the disc-they just spin really fast
Spray an small drop of safe window cleaner onto a Q-tip. Clean the laser lens carefully and then use the other end of the Q-tip to dry it. Use compressed air on and around the laser lens (do not blow on it). Clean your DVD disc and try again. If it fails again, try using a CD, if it will play a CD and not a DVD your optical pickup assembly is defective. If the CD wont play at all, your optical sled or spindle motor and/or drive is defective.
Most cases if cleaning doesn't fix it, it's cheaper to replace the entire DVD player. All portable DVD players are junk, regardless of brand.
Jul 18, 2011 | Video Game Consoles & Games
Denon DHT-500SD system and want what is on TV to come through 500
You could try the optical route. You should be able to use the analog RCA audio outputs of the TV to the analog TV or VCR audio inputs of the receiver as well. Select the appropriate input on the receiver and you should have TV audio.
Jan 02, 2010 | Denon DHT500SD System
Will noat load. message i get is cannot play
either the disk is dirty, or the lens on the optical pickup is. you can get a cleaner disk from any electronics store. if you don't hear the disk spin, you may have to replace the whole optical pickup (lens, laser, and motor assembly).
Dec 17, 2009 | Samsung DVD-VR357
Denon dht-500sd Cinema Systems is say no disk when there is a disk in the drive someone please help
That meen it can not read or detected the disc inside, usually is the laser assembly or spindle motor defective or simply got dust on the lens you need qualifier Tech to open and clean if it is success other wise it need to replace a new DVD deck assembly
I hope that geve you some ideas
Dec 07, 2008 | Televison & Video
Denon DHT-500SD - DVDs wont load
the problem may be two fold
1 the optical pickup assembly's lens may be dirty and needs to be cleaned (donot use any liquid to clean the lens just a soft cotton swab will do)
2 the optical pickup assembly has failed and can no longer read discs (if the laser or sensors inside the optic fail it is "blind" and can not "see" the disc)
start with the cleaning.
May 25, 2008 | Denon DHT500SD System
I have a Denon DVD-1920 DVD/CD player that is less than 18 months old. It has developed a problem whereby it refuses to play any DVD through to completion. It will play for a short period of time and then...
Yes, the unit must be opened to access the lens. Open up the top and you should be able to get at the optical assembly. Clean the lens using a cotton swab and alcohol. Try a DVD. If the problem persists, try playing a music CD. If the music CD plays but the DVD does not, the optics are starting to fail and should be replaced.
Dan
May 07, 2008 | Televison & Video
Replacement pickup lens assembly
try to replace the data bus(ribbon) running from the pickup lens to the motherboard, that may the problem before replacing the lens ,NOTE that lens faulty is not easy.
name ;emanuel mollel
mobile;255757566502
TANZANIA, IT student
May 07, 2008 | Denon DVM-2815 Multi-disc DVD Player
Denon DHT500SD System Logo
531 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
