Question about Porter Cable 362 12 Amp 4 Inch By 24 Inch Belt Sander With Cloth Dust Bag
Porter Cable belt sander
Porter Cable, model 362 belt sander won't pick up dust. Can I take apart? Does sander gum up when sanding old polyurethane? Do I need service manual?
Thanks
  • Anonymous Apr 06, 2009
    what size belt goes on the sander. it is a 3 bt 24
  • Anonymous Mar 18, 2014
    need instruction manual for a Porter Cable Model A3 Locomotive Belt Sander
    Sergeant:
  • 359 Answers
Try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
  • Allen Neal
    Allen Neal Jan 11, 2009
    try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
TOLEDO TBS-800 BELT
Where would I locate wheel rubber for sander Toledo tbs 800
Sep 15, 2012 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Sep 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
How to installe drive belt porter cable belt sandef
unplug tool first and then remove the 3 screws on the side cover to expose the pulleys, while apart clean the entire area with compressed air. start the belt on the smaller pulley and then ROLL it onto the larger one and after it is installed roll it a few more times to make fully seated. reinstall the cover and screws and you are ready to go. they made 2 different belt types for this tool so make sure that you get the correct one. the older one has ridges that go the entire area of the belt and the newer one has cogs spaced out.
Sep 11, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
I need a new belt for my porter cable 4X24 inch belt sander - model 362 - type 6 whisper series
I have had the hardest time trying to find a belt for mine.
I've made do with a 3 x 24 without any turmoil
I take it you are having similar problems
Mike
Aug 21, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 362 belt sander - the paper slips off
there might be a buildup of sawdust in the tensioning mechanism or the yoke might be bent. I would look at excess buildup in the mechanism first. there are 3 screws on the outside of the tool so you can remove the assembly as a whole. try and clean as thoroughly as possible. the mechanism should move freely and "snap" when lever released.
Jul 18, 2010 | Porter Cable Tools & Hardware - Others
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Just stopped turning, motor still running though
I take it that the rear drum stopped turning and if so the drive belt or one if the pulleys could be your problem. I would be doubtful if the gears are stripped. Give me the model number and brand and I will find a schematic for you. If this is the Porter Cable sander. on the side with the black cover you will find 3 screws that you can remove, UNPLUG tool first and take a quick look to maybe find your problem. Let me know if I can help further
Aug 09, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
My porter cable 362 belt sander will not adjust enough to center the belt. When the thumb adj. screw is completely free (lose), it rides about halfway across the roller and stays. I can't bring it back...
The slide arm mechanisms and tension arm, springs, etc. need a little light machine oil, 3-in-1, to make them slide easly, a few dropes will do the trick, do not over oil. Move the adjustment knob just hair at a time or it will over adjust, hope this helps you.
Mar 16, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 362 12 Amp 4 Inch By 24 Inch Belt Sander With Cloth Dust Bag Logo
806 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
