Question about Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153
Kyocera Mita KM 1530/ 2030 Copier Machines fax code c005
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
SOURCE: km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Posted on Jan 23, 2009
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
  • 990 Answers
SOURCE: kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
Posted on May 13, 2009
cbtmaya
  • 84 Answers
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Posted on Aug 31, 2009
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
My photocopier km 3060 displays error code c0120.what is the problem and the solution
Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed. Poor contact in the connector terminals. Defective drum unit. Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Cheers
Oct 17, 2014 | Kyocera Km 3060 Digital Copier With...
How do I clean spilled toner from the inside of a Kyocera mita copier?
Try using a small soft brush to brush it off while using a good hepa filter vacuum to remove the toner at the same time. Wear a good breathing mask to protect your lungs!
Aug 06, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
How can I replace the developer unit of Kyocera KM 4030 copier?
Did you install new developer powder into the new developer unit?
Jun 02, 2014 | Kyocera Mita Km-4030 Laser Copier Works...
Kyocera Mita incomplete code 634
That error code is actually a communication error caused by no response from the called station or a misdialed number. Make sure the number is correct and redial it.
May 01, 2012 | Kyocera KM-F650 Plain Paper Laser Fax
Kyocera Mita Photocopier KM-1530 Error code AP flashes at start up then C710
When AP flashes the toner is being replenished inside the copier. Wait a few minutes. You need to refill the toner.
Jun 09, 2011 | Office Equipment & Supplies
KM-2530 with C0050 error code ?
it's the the expansion card on the main board in the middle, has a yellow circular cmos battery. Either its faulty or popped out during moving the machine. if faulty, replace.
Mar 07, 2008 | Kyocera Mita KM-2530 Laser Printer
Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153 Logo
32 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
