Question about Panasonic Microwave Ovens
We have a Panasonic OTR model nn-294SF. It is shutting itself off after a few seconds of turning it on. We are trying to determine if we should fix it or just replace it.
It makes a clicking noise before it shuts down. Seems to end fairly quickly after the fan fires up.
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
  • 10 Answers
SOURCE: Pansonic Microwave Oven NN-S962-BF
Most likely the power capacitor is shorted.If you know someone that is just alittle familiar with electronics, they will know what to look for.The part will look like a somewhat long large silver 9v battery with two metal leads.Normally toward the back of the microwave and below the cooling fan.With a volt-ohm meter this capacitor can be checked.on the meter if you get a reading ,its bad, if you get no reading(open), its most likely good.Ninety percent of the time it will be bad.If it is, just replace with the same value and your ready to go.
Posted on Nov 06, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic microwave oven model nn-p994sf
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 22, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: my panasonic NN-T945SF starts, runs for a few
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Sep 12, 2009
The power keeps shutting off
see the details and fix it. God bless you
All microwaves have some sort of a cooling fan to help keep the magnetron and controls at a tolerable level. Most OTR models will usually use the vent motor for the cooling fan also. Countertop units have a small fan behind the control panel somewhere. Either way, if the cooling fan is not working and heat builds up, it is going to open a thermostat. On some makes, this thermostat might re-set itself as soon as the temperature cools down. Other makes, you will have to replace the thermostat or fuse.
If this is your microwave oven repair problem, you will need to check the operation of the fan. Below in the component testing chart, you will see how to test the fan. Also, if possible, make sure the fan is not obstructed somehow and not turning. Also check your fan relay at your control board for voltage, if no voltage, replace control board. This fan should come on at the same time any cooking starts.
Nov 15, 2012 | Panasonic NN-SD697S Microwave Oven...
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
My 4yr old NN-S262SF OTR runs for 2secs and stops whenever start
Hello
Microwaves use alot of power and should be on their own 20amp circuit. Get an electrician to put the microwave on its own circuit.
John
Nov 25, 2009 | Panasonic NN-S262SF Microwave Oven
Panasonic otr microwave model nn-s245bf, ventilating all the time, cannot use as microwave. thanks
I have the same problem. The control board (central processor) has caught fire. It's noticeable when you take the control panel off.
We need a new control board. I'm currently looking for how to get one. It appears to be a common problem.
Jun 16, 2009 | Panasonic NN-P794SF Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 20, 2007 | Panasonic NN-T694SF Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
