Question about Acer Aspire RC500 PC Desktop
No poer to computer
Where can i get a power supply unit
What! not if you know what your doing and that doesn't take much skill.
Replacing the power unit is a real pain on the rc500
1. You have to remove the motherboard to get it out
2. A replacement is hard to find, acer and acer parts don't stock one and have only found a couple on ebay which are really expensive.
3. Hard to migrate to a new case because of the form factor.
solution: Get a new pc or unit and salvage some of the parts
Posted on Mar 03, 2009
  • 30 Answers
You cannot change a power supply unit on a computer, you will damage the whole computer or you can even fry yourself.
Buy a new computer.
Posted on Jan 11, 2009
Perfectly working unit, now completely dead...power supply 220 v to circut pane is good
Is there an external outdoor isolator?
Make sure power going through switch as required( put volt meter on neutral and power cable to test not the earth and power) this can also be checked at terminals at outdoor unit, a missing neutral will cause power failure but will not trip the breaker,
Dec 20, 2015 | Heating & Cooling
Poer supply is not working. wont turn on
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
Dec 21, 2010 | OCZ ModXStream (OCZ780MXS) 780-Watt Power...
Hi i have a grundig gu22dvd the power supply keeps turning off can i buy a new poers lead and transformer
helen366, if unit continues to do same thing, I suggest you contact Grundig for warranty service to put it right again!!! You must tell them that it should not have premature failure of the internal "switch-mode-power-supply" and they should replace the unit with new or refurbished same model free of charge.
12fixlouie
Sep 24, 2010 | Grundig GU22DVDPX 22 in. LCD TV
I am not able to boot the computer
Replace the power unit. Go to eBay to find a reasonable priced one. They are fairly simple to replace, just make sure you are grounded and that you hook everything back the way it was. You will need the part number to find the exact one on ebay.
Oct 03, 2009 | IBM (24P6829) for NetVista M41 160-Watt...
Power Suply Replacement
Any good computer supply company should handle power supplies. The important thing is to get one rated for the same power. (300W, 350W, 400W, etc.) You can always go higher, but not lower.
Oct 18, 2008 | Computers & Internet
Carrier rfl 0601ehl
Try disconnecting the power supply from the circuit breaker tor 10sec., "on" it again and start the unit. If it don't correct the problem you need a qualified technician to check the defective parts in the unit.
May 02, 2008 | Heating & Cooling
Lexmark poering out!
sounds like either a bad internal control board, or a bad power supply..power supply is easier to check..voltage needs to be as specified on back of power unit
Apr 29, 2008 | Lexmark X5470 All-In-One InkJet Printer
Will not power in
IT IS THE POWER SUPPLY HAS TO BE CHANGED ONLY THING IT COS AS MUCH TO FIX AS TO BUY A NEW UNIT AS I WAS TOLD UNLESS U KNOW WHER I CAN FID A POER SUPPLY FOR THAT MODEL
Nov 16, 2007 | Yamaha HTR-5560 Receiver
Acer Aspire RC500 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
