Question about Refrigerators
Westinghouse wse7000sa freezer light exploded and now fridge isn't working
Freezer light has exploded and now fridge and freezer aren't working. How can we fix this?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Please recheck that model number. It is coming up as a washer.
Posted on Dec 02, 2012
3 Suggested Answers
  • 2128 Answers
SOURCE: RS265LABP freezer works but fridge doesn't.
if the evap fan motor isn't running then most likely this is you rproblem
Posted on Nov 25, 2011
  • 884 Answers
SOURCE: My Bosch KGU3420GB fridge freezer keeps getting a thick layer of ice in the bottom of the freezer which then 'welds' itself to the bottom freezer draw. Any idea how to fix this?
Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
Posted on Apr 23, 2012
How to fix a problem with hot dividing panel and sides of a Westinghouse WSE7000SA fridge freezer
It gets hot to defrost the fins on the freezer coils. You either have a bad timer or switch that tells the defroster to stop working.
Jan 28, 2015 | Westinghouse Refrigerators
Westinghouse fridge freezer fridge not working
What is the model number?
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 20, 2012 | Westinghouse Refrigerators
We have a model MBF1956KEB the freezer works but not the fridge
sounds like you have a bad damper,if you go here and look at part number 13 you can see it
http://www.searspartsdirect.com/partsdirect/part-model/MAYTAG-Parts/Refrigerator-Parts/Model-MBF1956KEB/3048/0161000/M0607105/00010?blt=06&prst=&shdMod=
it's broke in the closed position so no cold air can get blown over from the freezer and into the fridge section,open the freezer door and make sure you hear the fan blowing,also check around the freezer door and ceiling of the freezer and make sure there isn't any ice,common problem with bottom mount freezers is the door can get left open,warm air gets sucked into the freezer and ice forms in the air ducts,if all looks good i would say you have a bad damper,one more thing,remove the bottom kick panel there should be a tech sheet either folded up in the panel or taped on the cabinet wall down there,it will tell you how to do a diagnostics check to check all the parts like the damper,this way you know what part is bad.hope this helps you out and good luck.
Jul 28, 2012 | Maytag Refrigerators
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
Nov 25, 2011 | Samsung RS265LABP Side by Side...
My Westinghouse Rp241T fridge is not getting cold. I can hear the motor running but it isn't cold. The fridge isn't very old and I suspect the thermostat?? Where is it located or am I off the...
Hi, Sounds like there was/is a leak in the refrigerant system...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Refrigerators
Freezer works but fridge stopped working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jun 22, 2011 | Westinghouse Refrigerators
Hi, I've recently found that my westinghouse
if the back wall of the freezer is iced up the problem is most likely the defrost thermostat.
May 06, 2011 | Westinghouse Refrigerators
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
