Question about Indesit Washing Machines
Rumbling bearings indesit wd12x
Hello there
have a problem with the bearings on my washer/dryer. have a new set but cannot get the bolt off the back torelease pulley from the shaft. is this a left hand thread
  • Indesit Master
  • 3,463 Answers
It is a normal right hand thread, what you need to do is to apply heat to it with a blow torch,this wiil expand the metal , and should enable you to unscrew it.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
Drum is stuck and does not move after a noiny spin. pls advice.thanks
Sounds like possibly the main drum bearings have seized.
To check, remove the rear panel of washer, remove the drum belt, and try to turn the drum by hand, if it is noisy or rumbling, or not turning at all, then likely the the drum bearings have seized.
This is a major repair, and could be expensive!!!
Mar 17, 2010 | Indesit W 123 Front Load Washer
I have a 2 year old indesit wd12x been fine
could be the catch has broken you may have to force it open and new complete door is about £25.00
Mar 01, 2010 | Washing Machines
The dial stops on 2 will not spin or empty when switched manually it move round like a second clock through the programes. I have had the pcb. board checked by post with Q E R and they say its ok.INDESIT...
hello any spin problem can be down to the module board the fact you've had turn the dial which is the programmer sound like this is the fault if this is the case you may need to be looking for new washer. sorry to be negative i hope you find a solution
regards
shaun
Feb 28, 2010 | Indesit W 123 Front Load Washer
Where can i buy a door seal for an indesit wd12x
If you are in the u/k, then try yellow pages for washing machine repairers, or go to WWW.INDESIT.CO.UK, Then go to :after sales.
Please rate my solution.
Thanks.
Aug 11, 2009 | Indesit W 123 Front Load Washer
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Hi i have an indesit wd12x washing machine that does not drain the water. How do i get to the filter to clean it? Thanks
Your model of washer dryer is fittted with a self cleaning pump, and may not have a filter fitted.
To check if it has, remove lower plinth at bottom of m/c, and if there is a plastic panel there ,remove that as well.
If there is a filter fitted, you will see it at the bottom right front, it has a round cover, unscrew anti clockwise, remove and clean filter.
Pleas leave a fixya rating if you consider my solution appropiate to your query.
Thankyou.
Jan 29, 2009 | Indesit W 123 Front Load Washer
Broken handle
patience and an empty house got the job done try it yourself throw wife and kids out it works a treat
Dec 09, 2008 | Indesit W 123 Front Load Washer
The door on my indesit wd12x washer dryer will not open. The machine has finished the cycle and was on the tumble dry mode when it finished. The handle feels loose like a spring has sprung. Any...
slide in a piece of string around the door. if lock is on the right, pull round the door til the pieces of string are at left of the door and pull left quite firmly.
Oct 17, 2008 | Washing Machines
Washing Machines Logo
218 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
