Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb not recognised
While i insert my kingston 1gb usb to any computer its shows the message device not recognised and its malfunctioning. And also its ask to insert the device eventhought it is inserted
  • 57 Answers
The connector of you usb port of your unit kinston is need to re_soldering by using a soldering iron.or need to re-heat by hot-air unit.
kira_ryuk@yahoo.com
Posted on Jan 11, 2009
Kingston Datatraveler Windows 7.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
eventhough the device is not present, causing the said error.
Aug 15, 2012 | Kingston Computers & Internet
When i plug it in i get an error message "One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it"
remove all the usb connection to the computer and insert one by one and isolate tthe non recognised device cange the usb por and reload the drivers while conectin you will see adding new hard ware and the name of the device if you dont see and it shows unknow device the udb device is fried
Dec 30, 2010 | Computers & Internet
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My 8gb kingston flashdrive is showing up as usb not recognised on my laptop but my 1gb is fine .What shoukd i do?
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 09, 2009 | Kensington Electronics - Others
Kingston USB DTI/1GB Malfunction error
your USB Flash Disk is damage already, you need to be repaired your Flash Disk to read again in your PC.
Jul 22, 2009 | Computers & Internet
My noteoook got the problem with port usb
Since you have these many problems with your laptop, Firstly try to reformat the system and reinstall all the neccessary drivers. Many times reformatting works well as your OS might malfunction when you have virus or malwares in your laptop.
OTHER SOLUTIONS
a. for USB:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  8. Close the Device Manager window.
b. SD CARD
Your 1GB kingston card might have virus. use a card reader and reformat the card for future use.
c. Uninstall and reinstall the driver of your finger scanner.
Hope this helps,
~regards,
Jegan
Jun 01, 2009 | Lenovo 3000 N100 Notebook
Kingston dti/1gb
Have you tried finding the drivers for the USB Flash Drive?
Sometimes XP may need a compatibility drivers.
Mar 17, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When pendrive is connected shows device has malfunctioned
when i connedted my pen drive i show has malfunctioned
Dec 14, 2008 | Transcend (589307) Media
Error Message re: KIngston 2G Pendrive
since the device uses usb power there is no way that you might be able to retrive data if the computer wants to format it.
Dec 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
188 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
