Question about Boating
Adjust idle on 70hp johnson outboard - Boating
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 5495 Answers
SOURCE: We have very little reverse any thing above idle
There are two things to look for. With the motor off disconnect the shift cable. Pull the boots off the plugs so the engine can't kick back. Grab the shift lever directly on the motor and pull it in the direction reverse is. Turn the prop and you should be able to feel reverse click in. If you just barely feel it "tick" the gears, the shift rod inside the housing is not adjusted. If the reverse "bites" into place as good as forward then leave it is that position. Next, line up the shift cable but DO NOT connect the end with the shift lever. Put the cable in reverse and you will see a gap from the old setting to the where it has to be to work correctly. Then its as simply as adjusting the shift cable to match the lever.
The second possibility is the rubber hub in the prop. It could be slipping. But usually its gone in both directions when this part breaks.
Posted on Jun 27, 2009
  • 40 Answers
SOURCE: 9.9 johnson 4 stroke wo'nt idle
Your cabs need rebuild, something is stuck in the carb or air line cracked
If you have rebuilt the carb check for carb gaskett leak that caused and let the air flow in
When to choke is on the air is block and prevent air flow but allowed small amount of air to keep the engine running
After your engine warmed up the heat in the compression burn much faster so you have to let air in by turn off the choke
Good luck
Posted on Aug 20, 2009
  • 1168 Answers
SOURCE: I have a 1970's 25hp Johnson outboard motor. Last
Hello Adam.
If your propeller is OK, your lower unit will need some repair. It may be as simple as a clutch dog worn and not engaging the gear. Usually they give warnings of problems by jumping out of gear though.
Other possibilities are broken driveshaft, propshaft, or gears. If it goes into reverse the shafts are OK and the clutch and forward gear become suspect.
It was common for these engines to break at the top of the driveshaft where they were tapered.This would give you no motion at all and no previous warning of a problem.
Check the gear lube for metal particles and signs of water intrusion. I hope your repair is an easy one.
KL
Posted on Dec 08, 2009
  • 4 Answers
SOURCE: i have a problem starting my 70hp evinrude
YOU DONT SAY WHAT YEAR MODEL YOU HAVE, THIS MAKES A BIG DIFFERENCE TO YOU CHOKING SYSTEM
Posted on Dec 16, 2009
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Repair manual for a 3 Cyl 1988 70Hp Johnson outboard
Can't find any free ones but there is one for sale on e-bay right now. Repair manual for 3 Cyl 1988 70Hp Johnson outboard
Nov 28, 2015 | Boating
1999 Johnson 70hp 2 stroke outboard how can I disconnect the self mixing oil tank and premix oil and fuel myself?
the self mixing use variable rate which is much better then mixing it yourself. why would you want to change it?
Mar 18, 2014 | Garden
70HP JOHNSON OUTBOARD doesn't want to run with cowl on.
There is an air inlet at the upper back side of te cowl. Check if that is open...
Mar 07, 2014 | Seloc Marine Johnson Evinrude Outboards,...
Yamaha outboard 70hp Taco will go directly to 7k even when the ignition is on... motor idles & runs good
There Is An Adjuster Behind The Gauge Should Be At 12 Pole
If Not Then Gauge Probably Done
Feb 19, 2013 | Boating
Boating Logo
189 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
