HOW DO WE open the port of this modem
WHen i want to play modern warfare 3 it does't work perhaps the port are blocked and refuse the acess to the game
  • 2,072 Answers
Outgoing traffic isn't blocked normally on routers unless someone specifically blocks them in the configuration menu.
Posted on Dec 02, 2012
allanster
  • 60 Answers
SOURCE: nat type3 to type 2
Required Ports
UDP 20800
UDP 20810
UDP 28960
Posted on Jan 29, 2009
BlackHand-En
  • 68 Answers
SOURCE: hello , i want to
NATing will not be the issue..
PORT: 28961 should be open for you to play call of duty 4:modern warfare.
Jubert
  • 249 Answers
SOURCE: Can't Open Ports in my Router
Make sure that you set or assign a static IP to your playstation first through your dlink. This would ensure that your playstation would have its own ip address and wont change each time you restart your playstation. Once you have that fixed then you could use the virtual server and set it to open all ports for your playstation's ip address. If it still did not work then instead of using virtual server, try setting your Playstation as a demilitarized zone. If that still did not work I think it would be best to contact your ISP.
Posted on Jun 01, 2009
govinda123
  • 2260 Answers
SOURCE: How do i change my NAT from Strict to open on my
you will need to change the some settings on the router.
reduce the MTU. If the MTU settings on the router is 1500 then change 1365.
Also you will need to open some ports on the router.
Click here for more info
Posted on Dec 04, 2009
govinda123
  • 2260 Answers
SOURCE: i am trying to open
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Posted on Dec 13, 2009
Playing call of duty mw3
It's possible that you are suffering from lag issues when playing games online. Check your internet connections to see if everything is working properly.
During a mw3 match, do you usually watch the kill cams? They usually tell you how you died and to see if your opponent was obviously cheating or not.
Feb 23, 2012 | Activision Call Of Duty Modern Warfare 3...
Xbox live lagging
try to config your new modem properly........or contact u r isp
Apr 20, 2017 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
I am connected by an ethernet cable, and my internet works, but it wont connect me to the online server for modern warfare two. it works sometimes then cuts off. then for a while it doesnt work at all....
I think you need to open some ports on your router. If you do have a router you might as well change the MTU size to improve your bandwidth.
If you are directly connected to a modem then contact your ISP and verify if some ports are being bock for your game.
May 12, 2010 | Sony Playstation 3 (PS3) Console
My Modern Warfare 2 Game Wont Let Me Play... Please Help!!!
It could be your router or network settings for your internet. Do you use Port forwarding? The Playstation site tells you all the ports you need to use. Also try putting your playstation in a DMZ.
Mar 09, 2010 | Activision Call of Duty 4 Modern Warfare...
Dns error when trying to play online please
try restarting your modem and router, this works most times for me
Feb 26, 2010 | Activision Call of Duty 4 Modern Warfare...
I click on the play online and it says connecting to matchmaking server...it never goes any further than that.
Most likely you are behind a Firewall / or preset Router Settings. If this is the PS3 version of the game, most likely its the router. Double check with the specs for Port forwarding online, and make sure the ports are open to allow you to play.
-GamePorts required open / Notes Call of Duty 3Source & Destination port 3074 allow outbound + inbound on UDP and TCP. -
CoD in most instances uses the same ports for all there games. This is the first thing I found after looking through Google search. Hope it helps.
DrakeTech
Nov 11, 2009 | Activision Call of Duty 4 Modern Warfare...
Multiplayer problems
reset ur modem, router, xbox, and get the disc cleaned (resurfaced). mine did the same thing, i was told to do this. disc first, then b4 u play, reset everything. this worked for me. it might help u out.
Sep 19, 2009 | Activision Call of Duty 4: Modern Warfare...
Downloading game settings... never stops? when i try to find a game online
you have to port forward ur modem to open a port for call of duty 4 u can get port codes form infinity ward or sony by calling them its a process but it makes downloading game settings go away
Mar 03, 2009 | Activision Call of Duty 4 Modern Warfare...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
