Question about ASUS K8V-MX Motherboard
Motherboard not starting!
When i turn on my ups, both power led and HD led glows smps fan rotates,motherboard led glows, cpu fan rotates....without using the power switch itself...but no signal to monitor....motherboard not starting... wat could be the problem?
  • 57 Answers
Try to set the jumper setting of the cmos battery in *********** set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
Posted on Jan 11, 2009
P5p800vm no power
Your PSU would seem to have failed.
Aug 15, 2013 | PC Chips Computers & Internet
My pc Shut Off Automatically after few min(5-6),when pc is in boot screen options or booting from O.S. CD"
I missed your question, anyways. as it seems there might be the reason of over heating. I would suggest just remove the heatsink apply proper heatsink paste on CPU and replace your heatsink and fan. heat must radiate properly.
Nov 28, 2011 | ASUS P5G41-M Motherboard S775 Intel G41...
P4B-M standby LED lighted and CPU fan jerked a little and stopped when power is plugged into the power supply unit. The motherboard does not seem to power up/ CPU fan remain still even the power switch on...
This is an issue with the power supply (SMPS) in your computer... Replace the SMPS will fix the issue...
It is not adviced to service the SMPS, because servicing the SMPS will not give proper power supply to the board, which may result in damage of Motherboard...
Dec 15, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
I have a D946GZIS motherboard. It does not boot whenever i switch it on and press the power button. Also the power led is not glowing. What must be the problem..? pls help ..
Starting at the begining. The wall socket, the plug, the cable, the power socket on the SMPS at the back of your PC, the SMPS, the Output connectors from the SMPS to the motherboard. The power LED not glowing means that the power is not reaching the motherboard. Disconnect and reconnect the power connector on the motherboard. start. No start. Does the fan on the SMPS work? If yes then all components before the SMPS are doing fine. If no then most likely connection socket power cable to the SMPS may be the culprit. This has a lot of load on it. The PC and the monitor both take power from this socket. the answer to your problem lies in the answer to my question whether the fan starts in the SMPS or not. If yes then there is no output from the SMPS and the SMPS need to be given the due attention and if no then there is no power input to the SMPS and various cables and socketc need that attention. In case you need to and can remove and open the SMPS look for bulged or burst capacitors. If found, replace them. Those round cylindrical components.
Nov 27, 2009 | Intel D946GZIS Motherboard
Amd phenom faulty
Replace cpu fan , failed cpu fan might have caused CPU stoped working. If you are sure about the CPU fails then replace the CPU. If the problem seems continues after that too, then PC might have failed to boot due to other reasons. What shows on the screen once you power on the computer? There could be , motherboard , or harddisk faults too. Try unplugging other parts and see if the computer boots from CD or USD flash or floppy drive!! Once you know that motherboard works then replace the CPU. There could be BIOS setup problem. Did you check the BIOS for harddisk is set properly.
Sep 17, 2009 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
AsRock Motherboard won't boot. Need Advice.
Here's the solution!
Check if NUM lock glows if tapped on the Keyboard ::
Yes - If your Power LED is blinking change the SMPS, if it is Solid, change the I/O cables or RAM or Display Adaptr - whichever you think the problem to be.
N0 - Change the board.
PS. If processor is the problem, CPU fans won't spin in the first place.
Jan 10, 2009 | Computers & Internet
Cpu not starting up....power 2 cpu from smps is ok..
hi most of motherboard power on pin is 6 and 8 just short these two pins once if mothernoard starts it;s giving display else check ram or smps otherwise motherboard faulty.
Oct 03, 2008 | Intel Motherboard
Intel D850MV motherboard
If you hear no beeps and the led lights, and the fans stay on after striping all the components from the motherboard except for the cpu, and power supply, you have either fried your motherboard or your cpu. Its impossible to tell without more testing. I'm sorry but you either need someone to test it or you can buy a new computer (thats what I did). For about USD $300-$400 you can get a brand new computer with 500mbs of ram, 120gb hard drive and a 3 ghz cpu. If you look around you can get an even better deal.
Aug 15, 2007 | Intel D850MV Motherboard
ASUS K8V-MX Motherboard Logo
233 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
