Question about Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594
Snow thrower won't stay running
I have a fairly new craftsman 8.5 horse power snow thrower that stalls out during use. it starts up cold right away. I removed the old gas and replaced it with fresh gas and it worked fine . but the last time i used it .it stalled out after 15 minutes of use.
  • susieq525 Jan 18, 2009
    Mine does too. It will restart but run less and less time at each restart. It's only a year old!
  • Bill Todd Mar 07, 2009
    There are enough Google hits describing this problem that a design defect (perhaps involving the coil module) seems likely - and you'll also find several other suggestions to try if you just Google
    Craftsman "snow thrower" stalls
    - bill
  • 10,865 Answers
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Posted on Jan 23, 2009
If you put straight gas in a two cycle snow blowe will it smoke
Yes, right after the piston seizes in the cylinder. If the motor is still running but doesn't have a lot of power and smokes a lot, you are mixing too much oil in your gas. You should go for a 50 to 1 mix. Read the label on the two cycle oil bottle for the proper amount to use in your gas for this ratio.
Dec 17, 2010 | Mowtownusa Snow Thrower Starter Switch for...
Snow blower won't start
just take off the AIR filter and thar is a Big Hole thar spray sum starte fluid in the bigger hole and spray it for three sec then try an start it
Dec 17, 2009 | Mowtownusa Snow Thrower Starter Switch for...
SNOW BLOWER FRICTION WHEEL WON'T DISENGAGE
Use a good quality silicon lube and spray into the top of the cable. Do this until it comes out the bottom, a little at a time. Also, spray all pivot points. Don't use WD-40, it will freeze. Lube everything at the end of winter and again before winter.
Jan 31, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Jan 25, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594 Logo
674 people viewed this question
Top Mowtownusa Electrical Supplies Experts
Steve
ken skalski
Gene Haynes
Are you a Mowtownusa Electrical Supply Expert? Answer questions, earn points and help others
