Question about Polaris Pb4 - 60 Booster Pump
Wiring a Polaris 280 booster pump motor
Where do I connect black, red and white wires?
    Top Expert:
  • Polaris Master
  • 8,502 Answers
If connecting 120 volt see side panel for wiring change from 220 to 120 volt move brown and white wires then black to L1 white to L2 then green to ground or case
Posted on Apr 23, 2016
SOURCE: looking for wiring instructions for the
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Posted on Apr 29, 2009
john224
  • 1378 Answers
SOURCE: i have two wires 1 black and 1 white the third
One to each line. Be sure you set the motor to the same voltage as the line you are connecting. They are 230V out of the box and your wire colors indicate you are likely connecting the pump to a 115V line.
Posted on Jul 05, 2009
  • 128 Answers
SOURCE: Wiring on my Polaris booster pump came loose and I
The label on the motor has a wiring diagram for both 110 and 220
Posted on Sep 05, 2009
john224
  • 1378 Answers
SOURCE: Once the booster pump (for polaris 280) is turned
There is a bad seal and/or gasket in the pump allowing it to leak. It is usally the seal. Take it to a local electric motor or pump shop and the repair is probably under $50 total. You could also buy the parts to try it yourself, but the seal that pump takes (AS-1000) is a little tricky to seat properly. Besides, if your bearings are also damaged, the shop could fix that as well.
Posted on Oct 03, 2009
john224
  • 1378 Answers
SOURCE: why is my polaris 280 booster pump is revving much
Thank you for posting your question here on Fixya.com.
The booster pump can not turn any faster than its nameplate speed. If you think it is revving up, it is probably because it is running louder and/or rougher than normal. The pump seal and/or bearings are becoming worn and will need servicing. A local electric motor repair shop should have the parts for you to buy or they could repair it for you. Often times a gasket will need to be replaced as well but all told the repair should be ~$100 or so.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 09, 2010
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
Voltage 220 motor wiring
yes see side of motor move wires then black or color to L1 and white to L2 green to ground or case
Oct 24, 2013 | Polaris Pb4 - 60 Booster Pump
Installing replacement Polaris booster pump pb4-60. Removed old wiring without checking to see what went where. Dumb. incoming wire has a red, black , white. What goes where?
if 220 volt either red or black to l
1 the other to L2 white to ground or case make sure to measure between red and black you should get 220 volts ac
Aug 01, 2013 | Polaris Pb4 - 60 Booster Pump
My power supply has 3 wires, red, black and white. Pump wiring diagram has 6 posts for 1 yel w/blk, 2 brown, 4 black, 5 orange white 6 yellow. There is no red. what goes where?
see side of motor check voltage between red and black should be 220 red and white 120 volt black and white 120 volt make sure wiring is still for 220 from factory black to L1 red to L2 white to ground make sure white in box goes to green bus
Aug 01, 2013 | Polaris Booster Pump and Motor 34 HP
Polaris pool pump wiring
check voltage with a meter if ok and you check your wiring could have a bad motor from factory double check first
Aug 11, 2012 | Polaris Pb4 - 60 Booster Pump
Polaris pump turns on 10 seconds and then off then on and off
check wiring 220 vs 110 volt see side of motor for schematic check voltage first
Aug 04, 2012 | Polaris 280 In - Ground Pool Cleaner with...
How to change voltage on polaris booster pump pb4-60
see side of pump motor schematic shows low (120) vs high (240) volts move brown and white wires as shown then black or colored wire to L1 then white to L2 then green to ground or case
May 21, 2012 | Polaris Pb4 - 60 Booster Pump
I am replacing an old booster pump with a Polaris PB4-60. I have three wires, One Red, One Blue, and One Green. Now I know the Green is Ground, but which poles do the Red and Blue go? Both seem to say...
It is impossible for us to know what voltage you are running as you did not list that information here.
Typically a green-red-blue comination of wiring suggests 240 VAC connections.
Also, every motor you buy is required to have a wiring diagram on the side of the motor. This should tell you where to connect the wires.
IF you are running 240 v as suspected, both the red and blue wires are "hot" wires on the load side of your timing box. Simply look at the side of the motor and follow the diagram on wiring the pump.
Typically most motors in the USA use a L1 and L2 terminal to connect the 2 "hot " wires.
This pump does come factory wired for 240 volts, so it probably is just 1 each of the "hot" lines to L1 and L2.
Before connecting, make sure you confirm your systems voltage with a multimeter.
Below is a link to the installation manual for this pump. But it does not list electrical diagram since its on the side of the motor.
http://www.clubp.info/pdf/TL/P-134.pdf
Mar 22, 2011 | Polaris Pb4 - 60 Booster Pump
I have two wires 1 black and 1 white the third
Jul 04, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
63 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
