Question about Duplo Office Equipment & Supplies
DP460 - Error code EO16
Paper seemed to be periodically sticking to the plates for a time before the error stopped the machine
  • 749 Answers
SOURCE: Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Posted on Feb 10, 2008
SOURCE: Canon 850 E001 Error
I entered service mode and it fixed itself.
With the front panel open and the copier lid/carriage lifted up, I used a paperclip and stuck it in the small hole on the center of the front grey panel (the covering of the DC controller) . I simultaneously used a pen to hold down the tab in the slot on the lower left edge that makes the copier think the lid is down...then I hit the power button. It reset the error code and all is OK now.
Posted on Apr 24, 2008
SOURCE: CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Posted on Jan 21, 2009
tehnik_bdg
  • 91 Answers
SOURCE: Output section problem - Error code H5-01
H5-01 indicates that you have 5 continous paper jam in a row. It's generated when one of the paper feed sensors did not detect the paper, in your case the sensor might be the one that located in the exit section ( POD1 ). This photo sensor might be just covered with paper dust in between the gap housing, the gap is only 1 mm wide. You can check the functioning of this sensor by entering the sim mode 30( main code), 1(sub mode). After entering this mode try activate the sensor by moving the plastic actuator, if the POD1 display highlighted on and off it means OK. To enter the simulation mode go to the copy mode and perform the following procedures.
[P] [*] [C] [*] [Main code] [START] [Sub code] [START]
But first reset the error H5-01 by entering 14(main code) then 1(sub code), you might be already fix the problem.
Good luck
Posted on Apr 14, 2009
the kowalski
  • 86 Answers
SOURCE: MFC-620cn fax-2440C error 38
The only way to solve a Machine Error 38 is if there is an item/broken paper inside the machine that you can actually reach. Judging by the sound your machine seem to make, I'd rather guess that you got a mechanical error on your hands, which would require the machine to be sent to service to have it solved. Check for bits of paper or other loose items, otherwise - service.
Posted on Jun 02, 2009
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
I got a service code SC542. How do I fix it?
SC542 is a Fuser error code. It's a "fusing temperature warm-up error", basically meaning that the hot roller in the fuser did not reach the proper operating temperature within an allotted time period.
In order to clear this error, you would need to go into the service mode of the copier, then into the "System SP" section, and then power down the machine using the ORANGE ROCKER SWITCH located under the clear cover in the upper left corner of the FRONT DOOR..
Most likely it is time to have the machine serviced. Generally this happens when the hot roller has become worn, causing melted toner to stick to the roller and/or thermistors (temp sensors) that touch the roller surface. The hot roller, and other main components in the fuser, have a rated service life of 300K copies/prints.
One other possibility is that the paper you are using is too dusty. These machines have had issues with buildup on the sensors that is caused by a mixture of the paper dust and the silicone lubricant that is applied to the roller via the cleaning web. There has been a few service bulletins with regard to the build-up problem. There have been a number of part changes and setting adjustments to help combat this.
Mar 31, 2011 | Gestetner DSm660 Copier
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Brother Intellifax 4100 Fax machine. I may have pulled the paper cathrudge out to abruptly because a 3/4 spring was dislodged from somewhere - I have not identified where it belongs. As a...
best guess is it belongs under the paper lift plate in your paper tray, remove the paper tray and all the paper, there should be a metal paper lift plate in the paper tray, these are typically spring loaded to lift the paper into place. lift the plate and check the underside for the location of the spring, there is usually a retainer of some sort to hold the spring in place. once the spring is in place the tray should feed correctly.
Hope this is of some help.
Ed
May 09, 2009 | Brother IntelliFAX 4100 Laser Fax
ERROR CODES 016 AND 010
Unplug
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
set
91
set
1 (for off)
set
stop
look in the bottom of the paper tray and push backstop flush up to the paper
Jan 03, 2009 | Panasonic Panafax UF-333 Plain Paper...
Dec 12, 2008 | Canon CLC 1110 Copier
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
26 people viewed this question
Top Duplo Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
