SMPS reatart problem
Once the PC is switched off/ shut down it can not bw restarted. PC switch is OK. It starts only when the power plug is takenout for few minutes and put back again. Also, it works only if PC is started within 5-10sec of this, otherwise a faint LED remains on and PC doesent start. The SMPS is Quantum model -250
    Problem Solver:
  • 19 Answers
When i see this error i simply put my windows cd in to the computer and boot from the cd. Then you will have an option to repair windows. This repair will fix the problem and you will not lose any of your data.
Posted on Jan 14, 2009
  • bryanjatko Jan 14, 2009
    sorry about this post i posted to the wrong problem. as for this problem try a diffrent power supply.
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
The computer start after 3 or 4 attempt when I press the power button. When the computer is on & I restart my computer from Start - Turn off computer - Restart. - my computer shut down instead of...
If the computer is not truing in first attempt then check for the earthing is OK or not. Then check the power is correctly supplying or not. There may be a chance in loose connection of the switch of your cabinet. If the system is shutting down when you give restart, then it may be problem of power. If the power part is is OK then the operating systems is to re-installed or repaired.
Jan 13, 2011 | ASUS M2NPV-VM Motherboard
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows...
remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jan 03, 2011 | ASUS M2N68-AM SE2 Motherboard
CPU does not turn on..everything is plugged in..power cord is plugged into a working socket. what are my options?
its 2 cable that need to be plugged in from the power suppley, the wide cable and a 4 stick cable. both to the mother board. also you need to connect the fan cable to the mother board. how do you know that the processor doesent start ?
Oct 26, 2009 | Computers & Internet
Screen never switches on
please your monitor's switch is currently ok and warking?
second time your open the cpu couver and so the all add a smps sowaked in the motherboard add is ok. and you so the smos power
is down power you changed smos power and restart the pc and chack the ok.
Sep 27, 2009 | Gigabyte Computers & Internet
Window need to chech c desk on file system 32
some pc's like that when you connect the power ac will start automatically withen few minuts then shout off..this from the power suplly.. ragarding the notebooks if you plug the charger and hit power buitton in few minuts will shout down. check the powere switch and board that is Motherboard problem.. or try first the check the system, use safe mode
Sep 17, 2009 | Acer Aspire 3000 Notebook
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Tower wont power up
Check the switch which is putted on the outside of your SMPS. Check the switch/ I think the power connector is loose. Check it.
Feb 10, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
