Carrier outdoor Thermistor failure
Good afternoon, I have a Carrier 38YDA duel fuel system. The weather here is about 39 deg. F. This morning the unit cycles through the heat pump only for several minutes, when the unit try's to fire up the gas (LP) it shut off abruptly and give the following errors on LED (3 flashes w/pause then 2 flashes w/pause) I believe this is indicating an "Outdoor thermistor failure" with a secondary "High-speed operation" issue caused by the thermistor failure. Two questions: 1. Am I reading the code correctly 2. Can the thermistor be serviced by a home owner Regards
bobotfel
  • 236 Answers
SOURCE: AC unit not running
Try to off the power supply(circuit breaker) to reset the error and on again and start the unit. But if the symptom's persist you have to call for a qualified technician.
Posted on Dec 30, 2007
  • 659 Answers
SOURCE: carrier split 42G250HF-1(indoor unit
I'm not sure exactly what unit you have and what controls you have installed on the unit. But....there usually is a flash code schematic on the unit. Usually on the inside of the blower compartment cover. This should tell you what is wrong with the unit. It could have a low voltage short somewhere and is loosing the call for cool. So the answer can be a possible yes to your question but without knowing the flash code, it's hard to tell from my point of view. You might end up calling a service professional out to check it.
Posted on Mar 30, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
SOURCE: Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Posted on Aug 09, 2009
  • 215 Answers
SOURCE: how to repair Samsung AQV 12 FAN Air Conditioner
You can turn off the Thermostat, and the powers switch on the furnance and turn the breaker off in the breaker box wait about 20 - 30 minutes and turn the breaker back on, and the power to the furance back on and the thermostat, this should reset the system.
Melvin
St Louis
Posted on Oct 04, 2009
Blinking lights
not knowing what model I have chosen most common reply.
Check outdoor air thermistor which should read 12.29 K ohms at 20 deg celcius. if out of range replace. there cheap to buy.
Jan 10, 2014 | Carrier Heating & Cooling
My car likes to start in the. Morning but not in the afternoon and especially not when it's hot . I have changed my spark plugs and my fuel lines and it still does it what could it be .
Most Honda cars have a problem with the fuel pump relay where it works cold but not hot.
You need to know if you are lacking spark to the plugs or fuel pressure when it fails to start. If fuel pressure is the problem, check the relay.
Feb 13, 2013 | 1996 Honda Civic
My midland noaa weather alert is stuck in the tone mode and will not go to voice
Good morning, afternoon, evening or night; whatever time of day you you are viewing this solution posting. Thank you for choosing FixYa to assist you with your problem. Your problem is that your weather radio's 'Alert Type' setting is set on Tone and will not change to Voice. To change your 'Alert Type' setting...
1. Press Menu.
2. Press the down arrow button until you see 'ALT TYPE' displayed on your screen.
3. Press Select.
4. Press the down arrow directional button. You should see 'VOICE' on your screen.
5. Repeat step #3.
6. Repeat step #1 to exit.
You should now be able to receive voice alerts on your radio.Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again in the future, and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 28, 2011 | Midland WR-100 Weather/RDS Radio
Weather channel frequencies for Dover, Ol
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you with your request. You want the NOAA weather radio frequency channels for Dover, Oklahoma? Use the website below to obtain this information.
http://www.weather.gov/nwr/CntyCov/nwrOK.htm
Your county is located in the middle of the web page. Your county also has two frequency channels as well. So when deciding which one to use, consider the one that's nearest your area of residence. I suggest that you bookmark that website or put it in your favorites folder. Thank you for choosing FixYa as your one-stop spot for solutions to problems, questions, concerns or requests. I hope you stay safe this Tornado and Severe Weather Season. Remember to keep this radio on at all times and if you're noticing severe weather coming to your area, make sure to keep up-to-date with NOAA Weather Radio broadcasting. Have a good day, afternoon, evening, or night; whatever time of day you are viewing this solution post.
May 26, 2011 | Midland WR-100 Weather/RDS Radio
I need the s.a.m.e. code for county's in central Illinois,verm ,cham
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution posting. Thank you for choosing FixYa to answer your request. You need the S.A.M.E codes for the counties of Central Illinois? Well you have made the right choice in coming to this website to get help. Not only does the website I'm about to give you, show you the S.A.M.E codes for Central Illinois, but it also gives you the S.A.M.E codes for every county in the state of Illinois, as well as other information that may be important. Just click the link below and you will be just a click away from this informatable information.
http://www.weather.gov/nwr/CntyCov/nwrIL.htm
I suggest you print this information out or put it in you Web bookmarks or favorites folder. Thank you for choosing FixYa as your one-stop solution spot for your problems and requests. We appreciate your service and encourage you to stay safe this Severe Weather Season and hope that you keep updated with NOAA Weather Radio broadcasting stations. Visit our site again and I hope you have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution posting.
May 25, 2011 | Midland WR-100 Weather/RDS Radio
Co.code for volusia co. fi.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution. Thank you for choosing FixYa to grant you request. You want the S.A.M.E code for Volusia County, Florida. Shown below will be the website that contains this information.
http://www.weather.gov/nwr/CntyCov/nwrFL.htm
Your county is located near the bottom of the list. The county name is listed twice, but the S.A.M.E code is the same. The reason why the name is listed twice is because your county receives broadcasts on two frequency channels. This is good because if one transmitter tower goes out, you can switch to the other channel that's in your listening area. I hope you get good use out of your radio during this Severe Weather Season and that it keeps you safe and up-to-date. Thank you for choosing FixYa as your one-stop solution spot for your problems and requests. Visit our site again and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 15, 2011 | Midland WR-100 Weather/RDS Radio
Trying to set up midland wr-100 weather radio in Cass county Michigan but don't have the instructions for the radio.
Good morning, afternoon, evening or night; whatever time you are viewing this. Thank you for choosing FixYa as your one-stop spot for finding solutions to your problems and thank you for reading my post. So you are saying that you're trying to program the information for Cass County, Michigan, but don't have the instructions for the radio. Well you have come to the right place to find an answer. Not am I going to give you the URL address for downloading the manual, but I'd also like to give you the URL address for the information you will need to program into your radio. Here is the URL address for the manual - http://www.midlandradio.com/Resource_/OwnerManual/122/WR-100B.pdf. Here is the URL address for the programming information you need for your state - http://www.weather.gov/nwr/CntyCov/nwrMI.htm. Your county has four transmitter locations and three frequency channels. Choose the transmitter location and frequency channel that is nearest to where you live. If you follow this solution correctly, your weather radio should be ready to go. Hope this solution helps and thank you once again for choosing FixYa as your one-stop solution spot for all of your problems. Make sure you visit us again when a problem occurs. Have a good morning, afternoon, evening or night; whatever time you are reading this.
Mar 30, 2011 | Midland Weather/Hazard Radio with SAME...
What is the knob on the back used for?
Good morning, afternoon, evening or night; whatever time of day you are viewing this. Thank you for choosing FixYa to answer your question. You want to know what the knob on the back is used for? I believe that's the weather band fine tuning knob. This is used for switching between weather radio frequency channels (e.g. 162.400 MHz or 162.550 MHz). Use this to switch to a weather channel that is in your listening area. I hope this answers your question and thank you for choosing FixYa as your one-stop solution spot for all of your problems. Come back and visit our site again soon. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this.
Mar 05, 2011 | Emerson RP6247S FM/Weather/AM/TV Radio
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
03 silverado radio worked this morning.started it in afternoon no sound but display lights up.
No solution but same problem. However mine intermittent. It will come on and run the passenger side speakers and then shut off. All panel displays are on. Next day same thing. I think it has something to do with weather. When it is below 30 deg it doesn't work. When it gets 45 deg and up it works somewhat. It sounds like a bad circuit board connection.
Sep 09, 2010 | 2003 Chevrolet Silverado 1500
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
