Incorrect video signal - Televison & Video
  • 4 more comments
  • dsmallman Jan 11, 2009
    incorrect video signal alpine dha 5680p
    In car Alpine DHA 5680P. When I turn the system i on the rear screens display the Alpine logo then it displays the following 'Video signal system is not correct'
    This was already installed when I bought the car (Range Rover) 3 years ago but has just stopped working and displaying the message above
  • dsmallman Jan 15, 2009
    This was already installed when I bought the car (Range Rover) 3 years ago but has just stopped working and displaying the message above. No cables have been touched or altered
    Sergeant:
  • 233 Answers
Call ALPINE car audio Tech Support.... 1-800-ALPINE1
They will be able to talk you through everything you need to do.
Posted on Jan 15, 2009
  • Josh Crager
    Josh Crager Jan 16, 2009
    You can get alpines technical support line direct at 1-800-832-4101
  • 916 Answers
Are you using s-video or composite cables? and if you have both can you check to make sure you get the same error with each one and post the results.
Posted on Jan 11, 2009
  • 15,935 Answers
Simply dry another DVD.
NTSC disc is loaded. Your player requires PAL Region DVDs.
Nothing is wrong with the unit.
    Genius:
  • 1,447 Answers
Hi
What type of cable are you using when you connect it to your tv? whats the error message that you are getting? try pressing av/video on your tv's remote
keep us posted
  • 55 Answers
I'm guessing this is a new install? Or has it been installed and working?
  • Randy Dix
    Randy Dix Jan 11, 2009
    Ok, well cables rarely just go bad as has been suggested. If it was a new install it was possible you could have had a bad cable. If the dispay is initially showing the Alpine logo clearly and they showing you this warning. Unfortunately the problem is almost certainly in the head unit. I would make sure there are no loose connections, again not likely or else the problem would just be intermittent. I am sorry to be the bearer of bad news, but something in the head unit has gone bad. It would like be fixable if there is a certified Alpine tech in your area, or the head unit will need replaced.
    I wish I had better news for you. Sorry.
  • Randy Dix
    Just to make sure, before you scrap it. Check the video output configuration and see if it's set on NTSC or PAL. If this setting got changed, it would also cause this issue. Check this first please. You probably want NTSC, but whichever it is set on, try the other and see if the problem goes away.
  • 10,594 Answers
Don't you see colors in dvd video signal? What kind of error you see as incorrect video signal? let me know to help you.
    Sergeant:
  • 431 Answers
Check the output cable
  • 1 more comment
  • nematics
    nematics Jan 11, 2009
    can u tell me the exat model please
  • nematics
    change the cable line replace with new one
  • nematics
    may be due to changed the sound and the video cable according to the pin and the wire colour fix it and check it out
Turn tread mill on. counts 3 seconds and the belt does not move. the console goes blank after 8 seconds then e1 flashes.
follow this steps and fix it. See the diagram attached. God bless you
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.6698c5a0-3470-4d34-bd47-9422824cf011.gif
Of course you must lube the deck belt. see the video attached.
Sep 20, 2013 | Exercise & Fitness
I have a HD 1080 Medallion TV and I just changed it to Direct TV and the color is now in Black and white. Is there anything on the remote to fix this?
More likely the cables from the Direct TV box and the TV are incorrectly connected. My guess is that you have red, green, and blue cables that carry to video signal and they are incorrectly connected or one of the cables is bad.
Sep 10, 2013 | Mitsubishi Televison & Video
If a different device is plugged into the tv/video audio in jack it wont play in the back two speakers. They work when the dvd player is set in the dvd funtion
Well yeah, the DVD is internal so it can't possibly send an incorrect signal or be wired incorrectly.
What 'different' device are we talking about? It must be digital and transmitting a proper multichannel bitstream.
http://www.retrevo.com/support/Sony-DAV-HDX275-Home-Theater-Systems-manual/id/13756ag212/t/2/
See page 96.
Jan 10, 2011 | Sony BRAVIA DAVHDX275 Theater System
Hy does a colored tv record in black and white on
I suspect that you have the video standard is incorrect. Ensure you are recording in the same format as the signal you recieve. IE: NTSC or PAL. Whatever but they should both be the same. IE: Signal recieved = NTSC Video recorder must be set NTSC as well. Same goes for PAL.
Jan 13, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
Nintendo 64 game console, TV says no signal,
This usually indicates that you have the video cables connected incorrectly. The T.V. is just telling you that it's not getting any video signal from the console.
Check your connections, and if all looks well, perhaps the consoles video outputs or cable is shot.
Good luck.
Nov 24, 2009 | Video Game Consoles & Games
What does it mean when my tv displays solid blue and white lines
There is either no input signal or the wrong input signal (mixed up audio and video or component/composite ). You may also be trying to view on an incorrect input (vid1/comp1/etc.).
Jul 29, 2009 | Panasonic Televison & Video
No display from composite video input
Composite video are yellow RCA jacks and are made for analog signals of standard definition video. If you are connecting a digital source or a high definition output, it may be beyond the capabilities of the projector. You may be able to find a VGA to composite adapter if you laptop or whatever has a VGA output port. VGA is along the same lines of composite (analog, standard definition).
Mar 24, 2017 | Hitachi CP-X325W LCD Projector
No video, appears to be no video sync, diagonal rows of dots. Not an HDMI TV, switch is in TV position, cable checked ok by using a new cable, same problem
Sounds like you have an incorrect output signal from the Xbox or a fried chipset in the Xbox. Test the Xbox on another TV or monitor, test another video source on that same connection, if both of those fail, replace the Xbox. Hope it helps!
May 14, 2009 | Microsoft Xbox 360 Console
Compaq SR1350NX
check your video connection and memory ram
Dec 09, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Apr 29, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
397 people viewed this question
Top Televison & Video Experts
