Cannon ipf750 will no longer turn on (no lights, nothing)
Large-Format printer had been working great for a year or so. One day it would not power on. That week we had a power outage from Cal Edison - not sure if it that affected the printer. Are there any hidden fuses or thing to check for? Thanks Tom
frcs68
  • 1605 Answers
SOURCE: my printer won't turn on after a power failure.
No, there is no reset button.
disconnect the pirnter from the computer and the power cord. press and hold the power button for 30sec. connect the power cord, and connect it back to the computer.
Posted on Dec 02, 2008
SOURCE: Devise won't work at all
I had the same problem but found the solution. Follow exactly: (1)With the power on unplug the printer (2)Open up the printer pull the ink carrier to the middle.Then raise the gray bar from the cartridges and remove the printer head (3) Lower the gray bar, with the head out, and close the printer (4) Restore the power, wait til the printer wakes up (5) The printer should then tell you to put in the cartridges (6) Restore the print head and everything should be fine.
Posted on Dec 21, 2007
jackboy
  • 2985 Answers
SOURCE: canonmp830
Have you checked the fuse[s]? You don't mention your location so I cannot comment of what protection devices that may be involved. UK has fused 13amp wall plugs for example.
Posted on Aug 21, 2007
latinmcgyver
  • 208 Answers
SOURCE: Printer unable to communicate with computer
most easiest fix for this.. make sure in the properties of that printer.. under the PORT tab. make sure its set to usb not LPT. this is very common error.
Posted on Oct 10, 2008
efs_perpends
  • 1996 Answers
SOURCE: Cannon printer quit working suddenly.
Is it possible that the cord came unplugged from the transformer itself instead of the printer or wall plug?
A power outage shouldn't affect it, but a power surge can. Please use surge protection circuits on your computer equipment. It's so much cheaper than repairing or replacing them.
Take it from someone who learned the hard way....
You can try a printer reset. Turn the printer off, unplug the power and data cables from the machine. Wait at least ten minutes to allow the printer cache to be purged.(Canon's recommendation)
Then plug back in and turn on.
I hope this works for you! Good luck!
Posted on Apr 10, 2009
Je recois un message d'erreur 03800500-2f44
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Apr 20, 2016 | Canon imagePROGRAF iPF750 Wide-Format...
Cannon ip4200 no power nothing is there fuse internally ?
there should be a fuse in the power board . but with another shape. maybe is a small black cilynder.
Apr 19, 2016 | Cannon Office Equipment & Supplies
Canon ipf750 error 2F30
Esse error ? relacionado a troca da cabe?a de impress?o.
Nov 07, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Canon ipf750/upgrade firmware
I would first check the linear scale.That`s a small plastic strip ,positioned along the total lenght of the rail.Mind you ,I don`t have a ipf8000.But maybe the systems are the same.The linear scale is under tension ,by a metal spring.Check if the strip is not hanging loose.Also check the strip (linear scale) on dirt or ink splashes.If so clean it with alcohol (that`s what I did on a ipf5000).The scale runs through a slit ,at the back of the carriage.There are light grey patterns on the scale.The sensor on the carriage reads them ,and thus knows the position of the printheads ,with respect to the rest position.Check if the scale runs smoothly through the slit.
Feb 27, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Apr 10, 2009 | Office Equipment & Supplies
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Won't power on
Yep, Stop buying this printer. I doesn't work. You think it might have anything to do with the outlet you are using. I'm thinking some type of power surge or short hit all three printers with the same outlet. Did you plug all three in the same outlet "first thing" when you got the printers home? Are you using a power strip? I find that kind of strange for all three having the same problem. How long did the last printer you bought work? You said it worked great with the old power cord. Plug something else in the outlet like a lamp and see if the cord gets hot. I know that doesn't sound much like a solution but you gotta try something. Printers are getting expensive. Let me know what you did. I'd like to get to the core of this problem.
Jun 29, 2007 | Cannon i70 Printer
718 people viewed this question
k24674
