Question about Home
How to repair a broken click clack waste on a bathroom sink
4 Suggested Answers
  • 659 Answers
SOURCE: Surface scratches in my black bathroom sinks
You might try a vehicle buffer on them. If that doesn't work you will probably have to use a porcelain touch up kit that can be bought at your local hardware store.
Posted on Mar 30, 2009
  • 81 Answers
SOURCE: recently bought ex-display bathroom sink
I have to presume the sink is made of china and there is no repairing of china. There are two kinds of cracks, hairline from some sort of impact, and shrink. While the hairline crack can be visually disappointing, if it does not extend through the drain hole area it is a safe bet that the lavatory can be installed and used normally. A shrink crack resembles the cracks of a dried up lake bed and rarely cause any problems no matter where they are located. Rarely does not mean never.
Posted on Jun 02, 2010
canwoodjc
  • 3301 Answers
SOURCE: The pop up waste in
the plunger ( plug) has slipped out of the grove, or the bottom has split ,, heres a quick fix,, under the sink you will have a rod sticking out with a nut that holds in the shaft that is what moves the plunger up and down,, unscrew that nut and remove the shaft, there will be a tab that holds the rod to another piece of thin metal, just squeeze that and slide it off, once the nut has been removed, you can pull that out of the drain assembly, with a small flat head screwdriver,, pop up the plunger from inside the sink and inspect it,, if the lower tab on it looks good,, you will see how it slides in the hole, so that when the rod is inserted it will slip into that opening, in the plunger bottom, which makes the thing go up and down, once you've done that ( if the plunger was bad, just replace it, ) with the rod and nut back in place, you can adjust the tab so that the plunger goes up the desired length ,, here, this will make it more understanding http://www.youtube.com/watch?v=2kmOm55skb0 Please rate my reply and response
Posted on Aug 08, 2011
How do I set up the plumbing to convert a single bathroom sink to a double sink?
hot and cold supply is easy. You need to solder in a copper T-piece, and to that add a short length of copper pipe with an isolation valve and then connect that to a flexible braided pipe to the faucet.
Waste water not quite so easy. Have both P-traps fall to a cross pipe that goes to your existing waste.
A plumber could do the job in an hour and a half.
Oct 29, 2015 | Plumbing
We have the Kokols Wallmount Bathroom Pedestal Glass Sink Vanity Combo but the p-trap keeps leaking. How do we fix it?
Remove it, (Don't forget water will come out when you uncscrew it!!!) clean it thoroughly, especially the ends, clean and check seating of any rubber washers to make sure they are fitted correctly and not being distorted when the rings are tightened, reseat it with no force (it should sit naturally without having to force it in) and tighten rings. There are lots of videos on youtube showing how. If you cant stop it leaking buy a new trap. It's worth while looking very carefully for exactly where the leak is before you remove the trap, it might be coming from higher up. Repair Leaky Sink Drain Pipe
Jun 21, 2014 | Kokols Clear Vessel Sink Pedestal Bathroom...
I have had a saniflo operating fine behind my ensuite toilet for 2 years. The saniflo drains into the waste pipe after the AAV and before the bathroom sink. Recently when we flush the toilet and the...
may need a backflow preventer in the waste line under the sink..it is basically a ball on a spring..designed to make the water go only one way..I am guessing the wasteline was opened up with a plumbing snake..that pump may have too much backpressure from the head line..
Jan 25, 2014 | Plumbing
Click clack stuck
you need a grease that is good for water, usually white. use a tap or spindal grease.
The main problem hear is probably the type of soap that you are using. cheap ones usually have a high content of costic soda and this will remove any lubricant that you put on your click clack.
Dec 21, 2013 | Home
My hp officejet d135 all-in-one makes a "clacking" sound when turned on and the cartridge does not return to the middle when top lid is open?
hello, waste/ capping assembly is broken, i ahve tried many ways to repair without replacing, but found the best repair was to replace waste/capping station.
Sep 23, 2010 | HP OfficeJet D135 All-In-One InkJet...
We have a spring loaded sink waste which will not stay down and water drains away. Should I try and replace it with a simple sink plug although there does not appear to be any simple way of fixing this to...
ok. i can help :)
hi im Rossouw im a plumber. u have a click clack waste button yeah? well if so, it means if u press it in it stays down and if u press it again it comes up, if so u must thust unscrew the head "the part u put ur finger on if u press it down" and see if the rubber looks fine that is sepoust to seal the sink. if the rubber is fine u will see that remaining is the arm the head screws in to. unscrew that, tack it to plumbing shop and they will give u new part for cheap. no need to reaplace the hole fitting. let me know if u dont *** right
Jul 01, 2010 | Home
Ihave a two handle Moen bathroom faucet that the right handle came off showing a broken plastic part inside, how do I get the broken part out?
There is a little cap on the top of the handle, after removing in there is a philips screw under that and that will release the broken plastic part.
Mar 18, 2010 | Moen Kingsley Two Handle Bathroom Sink...
I recently installed 2 Kohler bathroom sinks 16x19". One of them keeping leaking at the bottom of the sink where the 1 and 1/4" pipe connects. I did not put plumbers putty in as instructed. It leaked, so I...
remove the waste fitting and clean off all the putty. Using a clear or white silicon put some under the waste fitting collar then insert it into the basin hole. Next put the washer and nut on and wind it up to about 1/2" from the basin. Using the silicon again put plenty on between the washer and basin ensuring complete coverage of the waste circumference. Hand tighten the nut until silicon pushes out from the sides of the joint. Finally tighten about 1/2 turn using water pump pliers.
Wipe off all excess silicon.
You can tighten a little more if the waste fitting is all metal but i'm guessing its plastic and it is possibly being overtightened.
Feb 22, 2010 | Kohler FANDANGO SELF-RIMMING LAVAVATORY...
Clogged bathroom sink
Try removing the **** Trap under the sink, there are two nuts one on each side. put a pan under the sink to catch the waste water in the trap first. ext loosen the nuts with a pair of channel locks or a pipe wrench turn the nuts counter clock wise direction till the nuts are loose slide the trap down and empty the contents of the trap into the bucket. Use rubber gloves so you don't get sick from germs. If the **** trap is plugged use a coat hanger to push threw the trap to get whatever is plugging it out. Rinse in a different sink, If it has the rubber gaskets I would recommend replacing the gaskets. Install in reverse. Do not over tighten the nuts or you will have to replace the parts. the trap looks like 2 opposing J .
Jan 03, 2010 | American Standard Contemporary Kitchen...
Mar 29, 2009 | Home
Home Logo
947 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
