Question about Motorola Mobility RAZR v3xx Cell Phone
Import csv data to razr v3xx - Motorola Mobility RAZR v3xx Cell Phone
I have a nextbook next6 tablet. it comes up with an error reading android.process.acore. all the time. can you help me.
This Android OS acore error seems to lie within contacts synchronization going wrong.
Because of that we need to clear all contacts (and restore them). This is how to do it:
Step 1 - clearing all contacts information
1.First of all, make a backup of all your contacts. You can do this easily by downloading ExportContacts from Market, fire up the app and export contacts to a csv file on your phone memory card. To be sure, copy the csv file to your hard drive too.
2.Then go to Menu -> Settings -> Data synchronization and turn of all synchronization.
3.Go to Settings -> Applications and tap Manage Applications. The list of applications will now take a while to load. When it's finished, find Contacts Storage, tap Clear data and tap Clear cache.
Note: all your contacts information will now be wiped out - but you're safe - you've already exported the contacts.
4.Turn on synchronization again (Menu -> Settings -> Data synchronization).
Step 2 - restore contacts information
Now we just need to restore the contacts information, which is saved in the csv file we created before. We will do this by importing the csv file to Gmail and let Gmail synchronize with the Android phone.
Note: You can import csv files to almost any email program or service, preferably Outlook or Gmail.
1.Login to your Gmail account -> Go to Contacts -> Click Import (top right corner).
2.Click Choose File -> Choose your csv file -> Click Import.
3.Done!
Now it might take a short while (a minute or so) for the phone to synchronize your Gmail contacts.
When the synchronization is finished you've got your contacts in Gmail and in the phone.
Shut for tablet down for 30 seconds. Boot it back up.
Sep 06, 2011 | Computers & Internet
How do I transfer data from my Motorola RAZR V3xx to v9 please?
I can get pictures off of the original phone. but not messages.
I know how to transfer photos to the new phone, but you have to text message them to yourself. obviously, unless you have unlimited pix and data, this will cost you alot on your next bill.
to transfer pictures off of the original phone:
purchase Datapilot
install it
hook your phone to your computer with a USB cable (doesn't have to be a susteen, datapilot, or verizon cable, this can be any cable.
transfer your photos.
Apr 24, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Import data to excelsheet insert in mysqltable query
You can save it as csv and use the file to insert using
LOAD DATA LOCAL INFILE '/importfile.csv'
INTO TABLE test_table
FIELDS TERMINATED BY ','
LINES TERMINATED BY '\n'
(field1, filed2, field3);
Feb 20, 2009 | Microsoft Office Computers & Internet
Need to add employee e-mail address to xerox 440st so we don't have to type it in each tme
NOTE: Accessing the Public Address Book is optional. The Document Centre will accept a Public Address Book file that contains a list of user names and their E-mail addresses. This file must be Comma Separated Values (CSV) format for the device to be able to read the file contents. The majority of word processing packages will allow you to create a CSV file. A selection of e-mail applications will also allow you to export a list of users in the CSV file format.
The completed CSV file is imported to the device through CentreWare Internet Services. The file must have the .CSV file extension. A valid CSV file format includes the name and SMTP e-mail address. The CSV file should be created so that the Names are in one column and the E-mail addresses are in the next column. For example, the following are both valid format CSV file entries:
Smith, Smith@company.com
Smith, John - john.smith@company.com
The order in which entries are displayed in the Public Address Book at the Document Centre will depend on how the entries are sorted in the CSV file.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution, as it requires knowledge of the network’s email system. Configuration of the LDAP directory settings requires the network to support LDAP Services.
The Document Centre will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address). Before you begin, print a Configuration Report and make sure the Document Centre has an IP address and the HTTP protocol is enabled.
From the workstation desktop:
  1. Click on [Start], point to [Programs], and select [Internet Explorer] to launch Internet Explorer.
  2. Click on [File] from the toolbar, then select [Open]. The Open window will be displayed.
  3. Enter the IP address for the Document Centre in the Address: field, then press [Enter] on your keyboard. CentreWare Internet Services window will be displayed.
  4. Click on [Index] in the upper, right corner of Internet Services. The Index window will be displayed with a list of hyperlinks to different areas of Internet Services.
  5. Click on [Public Address Book ] from the list of hyperlinks. The Public Address Book Settings window will be displayed.
  6. Click [Browse]. The Choose File window will be displayed.
  7. Browse to the location of your Address Book File (*.CSV).
  8. Highlight the CSV file and click on [Open]. The path for your .CSV file will be displayed in the Address Book File (*.CSV) field.
  9. Click on [Import Now]. An 'Are you sure you want to overwrite the existing Address Book? This cannot be undone' message may be displayed. Click [OK] to import the address book.
    NOTE: You cannot import a .CSV file with a blank name or e-mail field.
  10. An Enter Network Password window may be displayed. In the User Name: field, enter the system login of admin, in lower case letters. In the Password: field, enter the system password, then click [OK].
    NOTE: If you do not know the system password, contact your administrator. The initial system password at machine install is 1111 for the Document Centre 460|470|480|490, and 22222 for the Document Centre 425|430|432|440. If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed.
  11. Click on [Map Existing Address Book] to identify which headings in the CSV file contain the name and e-mail address to use in the Public Address Book.
    NOTE: If the CSV file contains names and e-mail addresses only, the file may map automatically.
  12. Click on the [Display Name] drop-down menu under the Imported heading. Select the heading that corresponds to the data you wish to use as the display name in the address book. The data you selected will be displayed in the Imported Sample field.
  13. Click on the [E-mail Address] drop-down menu. Select the heading that corresponds to the data you wish to use as the e-mail address in the address book. The data you selected will be displayed in the Imported Sample field.
    NOTE: If you are using a DC460|470|480|490, and if the CSV file does not contain a heading row, the drop-down menu will contain information from the first line of data in the file. For correct Public Address operation, the display name must map to a user name and the e-mail address must map to an SMTP format e-mail address, for example, name@domain.com.
    If you are using a DC425|430|432|440 and if your CSV file does not contain a heading row, the first row of data will be lost.
  14. Click on [Apply New Settings] to save any changes.
    NOTE: If you click on the [Clear All Addresses] button all entries will be removed from the current public address book.
  15. Click on the [X] in the upper, right corner to close Internet Explorer and return to the desktop.
Sep 23, 2008 | Xerox Office Equipment & Supplies
Motorola V3xx Razr Front LCD Screen Glass Repair
Your best bet would be to take it to your cellphone company and have them fix it for you.
Jul 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
CSV file to Import correctly into Excel 2003
Rudils,
The key is to import the data and not open the file directly.
1. Open a Blank Workbook in Excel.
2. Data, Get External Data, Import Data. (Excel 2007 is Data, Get External Data, Data from Text)
3. Browse to your .csv file and Select "Import".
4. Import Wizard should appear.
5. Page 1 Select "Delimited"
6. Select the row which you want to start the import.
7. click "Next"
8. In the Delimiters, select "semicolon" and/or other delimiters you are using.
Note: The bottom half of the window will preview the way the data is to be imported.
9. click "Next"
10. highlight each column of your data in the window below. For each column you can specify "General", "Text", "Data", or "do not import column" using the radio buttons in the top left of the Wizard box. This is an optional step.
11. Click Finish.
I hope that helps. Please add a comment if it not clear.
kpenguin
Nov 22, 2007 | Microsoft Excel for PC
CSV file to AS/400
FTP is "line oriented." It has no concept of 'database record formats.' It transfers strings of characters with essentially no knowledge of 'fields' or 'columns' that make up 'records.' A 'record' to FTP is usually just whatever string of characters that is found between record delimiters.
Trying to FTP into a DB2 externally-described database file requires having strings of characters that are (1) laid out to match the receiving record format and (2) either are already converted to the proper CCSID and transferred as BINARY, or are ASCII characters that would result in conversions to all the right characters and transferred as ASCII.
Regardless of which alternative is chosen for "(2)", the handling of record format positions that would match up with packed-decimal or other non-character type fields would be very tricky.
That's where a somewhat 'standard' file format such as .CSV comes in.
However, you don't transfer the .CSV file directly over the top of the DB2 file. Instead, you transfer the .CSV file into a simple directory on your AS/400 and then use it as the source for a DB2 import function. On your AS/400, the import function is most often the CPYFRMIMPF command.
The import takes the .CSV file and handles all of the mappings for field positions and data types.
As such, the sequence becomes (1) FTP the .CSV file to the AS/400, and (2) run CPYFRMIMPF on the AS/400.
Note that the format of the .CSV file makes a difference. You need to ensure proper CCSID settings, proper quoting where necessary, proper record separators, etc. Make sure that you generate a .CSV that can be converted to the record format of the eventual target database file. Lots of possible details, but _far_ easier than trying to construct a matching DB2 record format on a different platform.
Sep 19, 2007 | Computers & Internet
Motorola Mobility RAZR v3xx  Cell Phone Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
