Question about Weedeater Garden
How to take off flywheel key on a weed eater gas blower
  • 398 Answers
SOURCE: wont start
try some starting fluid in the intake, clean the spark plug. is it an old blower?
Posted on Mar 20, 2009
SOURCE: WEED EATER BLOWER BV 1800 FUEL FILER REMOVAL AND REPLACEMENT
According to the Weed Eater Instriction Manual, page 8:
REPLACE FUEL FILTER: To replace fuel filter, drain unit by
running in dry of fuel, then remove the fuel cap/retainer assembly
from the tank. Pull filter from tank and remove it from the the
fuel line. Install a new fuel filter on fuel line; reinstall parts.
Tip: Sears outlets have a big selection of tune-up items for
blowers, etc. Try them for needed parts.
Posted on Apr 02, 2009
Healeyman
  • 1198 Answers
SOURCE: ryobi weed eater will only run if i hold the choke down
Mine won't spin up till it is good and warm. Check the end of the fuel line in the gas tank to see if it is clogged or dirty or slimey. Make sure the end has not fallen off.
Posted on Apr 30, 2009
highspeedsan
  • 61 Answers
SOURCE: I have a Weed Eater Barracuda leaf blower but
http://72.3.225.179/manuals/545117523e.pdf
Copy and paste. It will take you to .pdf for your Barracuda
panilling9
  • 284 Answers
SOURCE: remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
Posted on May 26, 2009
My hand held blower wont spark plug and carb.replaced still wont start
If the plug is wet with fuel and it is firing then pull the muffler and for a struck ring. Struck and bad score cylinders will cause one not to start as you need at least 100 psi of compression to ignite the fuel mix.
These are okay then check the ignition of the flywheel to coil relationship as it could be a sheared flywheel key. Note most 2 cycles are now using cast in key as part of the flywheel itself.
Mar 14, 2015 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Weed eater fb25 won't start
This blower is fuel sensitive! Gas and oil mixture has to be correct. Too much oil will cause carbon buildup in the cylinder. In my case my blower would not start after several uses this season. I checked EVERYTHING....spark, fuel delivery, air filter.....then checked the flywheel which has no separate key....the key is cast into the flywheel. Read somewhere about the carbon buildup so took the cylinder off and viola! The piston ring was firmly stuck in the piston groove plus the cylinder was carbon scored. I tried to gently pry the piston ring free but it was so firmly stuck, it broke. Not worth fixing. Take the muffler off and you will be able to see the piston ring....use a small pick or something to see if the ring is free. If not, proceed to tear down or throw out. I was able to see scoring on the piston and determine my ring was stuck this way. Remember the elements needed for successful ignition...fuel/air...spark....compression. Stuck ring = low compression. The last time you ran the blower the ring became stuck...the engine continued to run because of the engine rpm's but when you try to start at low RPM's, no luck.
Jan 18, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
GBI 20 Weed Eater Blower ran out of gas and will not restart What to do to restart?
somewhere on it is a primer button pump it a few times and choke the blower it should start
Sep 18, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Weak spark
check the gap between flywheel and coil should be 010.gap.allso check magnet on flywheel.let me know what you find out.o if spark still weak change coil.let me know.ok
Jul 23, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
22 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Thomas Perkins
Thomas Perkins
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
