FixYa.com
Tags:
Onkyo HT-SR800 System
Surround sound
posted by twinlava on Jun 07, 2007
I just bought the HT-SR800 but I am only getting sound from the front speakers when I use the FM or AM radio. I am only hearing the front speakers when using an older CD player. When the system went through the automatic setup, I heard the test sound go to each of the 7 speakers. Right now I have speaker set A chosen.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 07, 2007
Thanks for Trying (70)
dsom
Rank:Wiz Wiz
Rating: 80%, 64 votes
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 03, 2008
Not Rated (0)
kilonen
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
I had same problem with an Onkyo. Turned out I had inadvertantly selected the wrong FM tuning mode - pressed the button to get back to auto - and then the surround processing sent a signal to the back speakers.
Can you Help with these Home Theater Systems problems?
PROGRAM ONKYO TO THE COMCAST HD...
program onkyo to the comcast hd... Answer This...
need help understanding...
I am just about to finally plug... Answer This...
Cutting off and stayin in Stand...
I just bought this thing a... Answer This...
Display on Receiver
Hi. We just purchased this HT... Answer This...
Onkyo HT-SR800 buzzing noise...
We just hooked up our HT SR800... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
