Question about Breezaire WK3000 Wine Cellar Cooling Unit
Breezaire WK 3000 Wine Cooler: Case bottom is rusted & leaks water. Are parts available? Is repair an option?
Are replacement parts available? Is repair an option?
  • 28 Answers
SOURCE: Inside coils are getting iced up.
One or both coils (indoor and outdoor) are dirty or plugged. Take the unit to a reputable repair shop and have it cleaned and oiled. This should be done at least once a year anyway.
It's possible that it might have a leak. The shop that cleans it can check it for you after they clean it. If this is an old unit, it probably wouldn't hurt to have that done.
Posted on Jul 08, 2009
  • 405 Answers
SOURCE: Breezaire WKCE 1060 unit in
HI.There might be some possibilities when it emits noise.First if the bossing of the fan from the shafting connecting the motor is already lossen,so when the fan starts to rotate it will make noise it will no longer as fit as the original one.Though it is not advisable to ke the unit open while its working,you can check how the motor works whenhileth unit is open for you to observe further
Posted on Jul 31, 2011
WCISERVICE
  • 50 Answers
SOURCE: Have Breezaire WKE3000, unit runs
POSIBLE FREON LEAK
Posted on Aug 16, 2011
WCISERVICE
  • 50 Answers
SOURCE: I need a wiring diagram for a Breezaire WKE 8000
THE MANUFACTURER WILL PROVIDE YOU WITH A DIAGRAM OF THE CONECTIONS FROM THE CONTROL BOARD TO ALL THE COMPONENTS THE BOARD CONTROLLS.
MIGHT HAVE TO INSIST ON THE REST OF THE DIAGRAM SPECS BUT THEY WIL PROVIDE THEM TO YOU
858-566-7473 BREEZAIRES NUMBER
Posted on Aug 18, 2011
WCISERVICE
  • 50 Answers
SOURCE: I have a WK Breezaire.
YOU CAN TRY USING A SHOP VAC TO **** OUT BLOCKING MATERIAL OR TO BLOW AIR THROUGH THE DRAIN HOSE TO PUSH THE BLOCKING CONTAMINANT.
BEST WAY IS TO DRILL OPEN THE UNIT USING 1/8 DRILL BIT TO REMOVE THE RIVETS AND TAKE THE COVER OFF, THEN REMOVE THE RIVETS THAT HOLD THE FAN DECK TON ON THE FRONT OF THE UNIT AND TWO ON THE BACK OF THE UNIT TO BE ABKE TO REMOVE THE INSULATION AND EXPOSE THE DRAIN HOSE HOLE, FLUSH WITH LOTS OF WATER AND A BRUSH AND ALLOW UIT TO DRY WELL BEFORE RECONECTING TO THE POWER.
Posted on Aug 28, 2011
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
POOL OF LIQUID FROM VESTFROST WINE COOLER ON FLOOR
it's not the refrigerant - that is a gas. It may be water from inside, or oil from a leaking pipe. If it's oil it's not a diy job
Apr 15, 2014 | Breezaire WKL 4000 Wine Cooler
I have a WK 4000 with the condensation drip line that keeps popping out. What is the best way to fix this permanently?
YOU CAN BUY A NEW DRAIN HOSE FOIR LIKE $15 TO $20 WITH A NEW NIPPLE ON IT AND DO ALL PREVIOUS STEPS EXPLAINED TO UNCLUGG THE HOSE.
Sep 02, 2012 | Breezaire WK 4000 Wine Cooler
This unit is 15 years old and the drain tube was never hooked up believe it or not and it leaked terribly with now a rusted out bottom. The unit works however and I was wanting to fix it. Can a new...
IF YOUR UIT IS IN FACT 15 YEARS OLD IT CAN NOT BE A WKL MODEL, WKL ARE DIGITAL UNITS, WHAT YOU HAVE IS A WK4000 WITH A SCREW TEMPERATURE ADJUSTMENT IN BETWEEN THE GRILLS.
A 15 YEAR OLD WK 4000 IS AN R-22 SYSTEM AND NOT WORTH REPAIRING AND IF THE METAL IS RUSTED YOU CAN NOT BUY MORE METAL BASES FOR THAT UNIT FROM THE MANUFACTURER, BREEZAIRE HAS DROPPED ALMOST ALL THE COMPONENTS FOR THE UNIT ONLY THINGS AVAILABLE ARE FANS,COILS AND THERMOSTAT.
BUY THE REPLACEMENT WKL4000 DIGITAL SAME DIMENSIONS AND COOLING CAPACITY.
http://www.breezaire.com/wp-content/uploads/2011/04/WKL-Insrructions-3-11.pdf.pdf
CHECK THE LINK FOR THE INSTRUCTIONS ON THE NEW WKL UNITS
Sep 19, 2011 | Breezaire WKL 4000 Wine Cooler
I have a WK Breezaire. The condensation line is clogged up. I need to get inside the unit to clean out the pan.
Aug 24, 2011 | Breezaire WKL 4000 Wine Cooler
I have a Breezaire WK6000 which froze up and then stopped working. I am looking for someone to replace and install a new unit
DEPENDING ON AGE OFTHE WK IF IT IS AN R-134 UNIT(CHECK TAG ON BACK OF UNIT) AND IF ITS NOT RUSTED OUT IT SHOULD BE REPARABLE , BUT IF YOU WANT TO REPLACE I WOULD RECOMMEND A WKL MODEL OVER A WKE
Dec 11, 2010 | Breezaire WKE 6000 Wine Cooler
WKL 3000 is creating excessive condensation and icing on the bottom of the unit. It is about 13 years old.
There will always be condensation. The problem may be that the drain that carries the water off is partially plugged.
Sep 20, 2010 | Breezaire WKL 4000 Wine Cooler
Jul 08, 2009 | Breezaire WKL 4000 Wine Cooler
Breezaire WK3000 Wine Cellar Cooling Unit Logo
95 people viewed this question
Top Breezaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
