Question about KitchenAid KBRP20ERSS Stainless Steel
Buy new stainless steel door panels for the KitchenAid KBRP20ERSS
Just the front panels for the refrigerator and freezer doors? Looks like they can just slide out.
    President:
  • KitchenAid Master
  • 2,651 Answers
Sorry previos post listed part numbers for you, nad yes removing the handle will alow them to simply slide out
Posted on Jan 11, 2009
WHIRL POOL STAINLESS STEEL FRENCH DOOR- BOTTOM FREEZER MODEL NUMBER GI5FSAXVY
You should be able to buy replacement stripping at any local hardware and furniture store.
Sep 16, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
KitchenAid - Is it real Stainless Steel?
The fridge freezers are called stainless steel but it is a term that is used more for marketing than an actual statement of what they are made of, the grade of stainless steel they use is very very low grade and the manufacturers of the appliances coat the steel with a protective clear coat to stop corrosion. This is why it is magnetic.
Mar 06, 2012 | KitchenAid Refrigerators
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Replace door on Kitchenaid bottom freezer 2 top door model
Switch from white to red wines and drink at room temperature, or buy a new single door cooler that suits your fancy. The bolts may line up because of a single door model that shares the same chassis, but the cost and trouble of getting a matching door may not be worth the trouble.
Feb 14, 2010 | KitchenAid KFCS22EVMS Stainless Steel ...
Beeping sound from the top.
Good day,
Have you tried to check on the door switch? it actually controls the lights and the fan motor to the fridge.
mycho
Feb 15, 2009 | KitchenAid KBRP20ERSS Stainless Steel
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
Jan 19, 2009 | Sub-Zero 561 / F
Tryng to buy stainless steel door panel for KitchenAid KBRP20ERSS
you can call you whirlpool direct, (number is inside refrig/owners guide.)or local part warehouse, heres the part numbers,prhaps you can find a supplier online
8208307--refrig door panel
8208308-- freezer door panel
Jan 11, 2009 | KitchenAid KBRP20ERSS Stainless Steel
KitchenAid KBRP20ERSS Stainless Steel Logo
225 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
