Question about Exercise & Fitness
What is the volts and miliamps of the ProForm crossover Elliptical Trainer PFES80040 ac adapter
Transformer
  • 103 Answers
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Posted on Nov 13, 2009
  • 103 Answers
SOURCE: how to remove and replace a motor belt on proform
Hello there. To replace the drive belt (motor belt) follow this procedure.
1)Remove power to the machine
2)remove the hood cover (3 screws on the rear of the cover)
3) loosen the adjusting bolts for the walk belt located on the opposite end of the walk belt from the hood assembly. Loosen the adjusting bolts 10 full revolutions. This will loosen the walk belt.
4) You should then walk the drive belt off of the front roller/pulley assembly by pushing the belt to one side while turning the motor. If you are nable to do this you will need to loosen the 2 bolts holding the drive motor in place.
5) After removing the drive belt you can then slide the drive roller to the side out of the frame and it will slide out the other side of the bracket. This will allow the belt to be removed from the front roller and be replaced.
If you had to loosen the bolts holding the motor you will need to retension the drive belt by pulling the drive motor back while tightening the bolts. This will require another person to help tension while you tighten the bolts.
You can then retension the walk belt using the adjusting bolts and retightening them 10 revolutions.
Good Luck Tim
Posted on Dec 16, 2009
  • 10865 Answers
SOURCE: need to know size of ac power cord to get ie.
hello. Your proform can be operated on electric or with 4 D cell batteries. If you do not have the power supply cord that comes with this unit you must order one from the company. The information on how to order one from the company is at the end of the manual. Here is the manual:
http://fitness.manualsonline.com/mdownloads/ae475852-929e-4cad-8d5a-1ac56f09731a.pdf
Kindly rate my answer. thankyou.
Posted on Feb 03, 2010
mastermaid
  • 502 Answers
SOURCE: Manual for Trimline E418 elliptical cross trainer
Get the manual here
Posted on Aug 10, 2011
ercupa190
  • 12223 Answers
SOURCE: spirit-esprit-el1-elliptical-trainer no display
1) replace the batteries by new one with alkalines type and using the same polarities DO NOT use another mark example sony vs everyready. Clean the contacts batteries.
2) Adjust the REED swtich, clean it, tight the connector very well, see the diagram and proceed.
God bless you
Posted on Nov 12, 2012
I have a Proform Hybrid elyptical/incumbent bike and the resistance levels no longer work .How do I repair this?
Hi There ,
There might be a problem with the resistance motor.
Ring Icon Fitness, they are the distributor for this brand world wide.
Sep 10, 2014 | Proform Hybrid Trainer Elliptical And...
Proform elliptical 825 can't get the display to stop blinking?
If you are not working out on your trainer, the display should flash for a while and than completely stop. But if it continues to flush, please call proform support.
Feb 26, 2014 | Proform Exercise & Fitness
Owners manual
We lost ours in a move too! It plugs in near the bottom/front on the R side of wheel cover. What are the specifications of thr replacement? How many volts output, etc? Thanks
Nov 07, 2013 | Ironman Fitness Achiever Elliptical...
Proform hybrid trainer squeaks - elliptical portion only. Everything tight. What do I do now?
Locate the site of the sqeak. Then spray WD40 or similar spray lubricant thoroughly in and around the screws in that area using the straw attachment. I did just that and it took care of the problem.
Aug 07, 2013 | Proform Hybrid Trainer Elliptical
What is the output of the ac adapter for the schwinn 430 elliptical???
It should be at the bottom of the machine in the front facing away from you if you are on it.
Nov 02, 2010 | Schwinn 430 Elliptical Trainer
I have an Eliptical Trainer BY-430E. I keep getting Error 1 every time I turn it on to use it. Does anybody know how this can be repaired. Thanks in advance
Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
Jun 28, 2010 | Schwinn 430 Elliptical Trainer
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Exercise & Fitness Logo
71 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
