Question about BenQ FP567s 15" LCD Monitor
FP567s Ver.2 ON/OFF
When I press on the ON button the "Benq" splash screen comes on then Windows XP desktp shows just for a second. After this I get a blank screen and the power button is ON.. Anyone run into this problem..help
  • foojunkie Nov 07, 2007
    I have some kind of the same problem i have a Benq FP737s its about 2 years old and now , i just have image for around 1 second and then i just get a black screen, the power led its always on (green) , and each time the i hit the power button its the same again 1 sec image and then black screen.
    My question is , its simple to fix this and low cost ?
  • BenQ Master
  • 12,061 Answers
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Posted on Jul 24, 2007
Is there a way to change windows xp bios settings after boot up, particularily using the command line?
My knowledge of using the command line is equal to my knowledge about astrophysics. Zero.
You can change BIOS settings in the BIOS Setup utility. After the computer manufacturer's splash screen, (Logo screen), and at the bottom of the screen, are shown the key/s to press to enter BIOS Setup.
Goes by real F-A-S-T. Try to write it down. Let Windows load all the way, then restart the computer.
As SOON as you see the manufacturer's splash screen, start tapping on the key/s to enter BIOS Setup. If you miss this window of opportunity, let Windows load all the way. Turn the computer off normally. (Wait at least 20 seconds) This time as Soon as you press the Power On button, start tapping on the appropriate key/s. (In 2 second intervals) You don't get as far as the splash screen? Then unplug the computer from power. Observe Anti-Static Precautions. Remove the CMOS battery, (CR2032), for 1 minute. Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. Let go of the Power On button. Do this procedure two more times. Install the CMOS battery. Plug into power. WAIT 1 minute, turn the computer on. This procedure will set the BIOS Settings back to the factory default settings, and clear CMOS Error Codes. Post back as to your findings.
Sep 14, 2011 | Computers & Internet
I have LCD monitor screen & windows xp as operating system.i cannot remove auto adjusting message box. it flashes on screen after every 2-3 seconds & due to this my screen will auto adjust at every...
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
Mar 20, 2011 | BenQ FP71G+ 17" LCD Monitor
I have fp567s monitor\r\nit often goes silver while starting and it needs monitor off button to be pressed (sometimes twice/thrice) for windows / boot screen to come alive i have re-installed the driver...
The silver hwite/grey screen means that the LCD panel is not getting the signals, 5vdc from the logic board. Try reseating the connections between the logic board and the LCD panel first.
Also check the power supply caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Dec 13, 2010 | BenQ FP567s 15" LCD Monitor
How do i get into safe mode on a thinkpad r50?
Please restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Mar 10, 2010 | IBM ThinkPad R50e Notebook
Benq FP567s color monitor driver
Enter this URL
http://www.benq.com.au/support/downloads/downloads.cfm?product=465&page=downloads&dtype=D
Apr 26, 2009 | Computers & Internet
Benq Q7S3
Video Graphics Card in Computer "BAD" !
Nov 15, 2017 | BenQ FP567s 15" LCD Monitor
BenQ fp567s won't come on
I am looking for the LCD panel from a 567 V2.
If you can't repair the problem e-mail me and I would like to buy one from you for parts.
sack4000@aol.com
Jul 08, 2008 | BenQ FP567s 15" LCD Monitor
BenQ FP567s 15" LCD Monitor Logo
170 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
