Question about Whirlpool Refrigerators
Condensite on the ceiling in Whirlpool Gold top-mount refrigerator gb18dk
Drops of water are on the front of ceiling in the fridge. How to fix this problem?
  • 4,339 Answers
This sounds like a seal leak. Take a dollar bill and close the door with the dollar across the strip and pull. It will be loose where the leak is.
change the seal.
Posted on Dec 02, 2012
  • Elena Dec 02, 2012
    Thank you Mike. The part I have to look will have name gasket or seal?
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
aborcass
  • 2651 Answers
SOURCE: refrigerator whirlpool model wrx38rwh6
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 26, 2008
jtbjtb
  • 135 Answers
SOURCE: Roper Refrigerator, top freezer leaking water into refrigerator
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Posted on Jan 01, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
aasc
  • 1606 Answers
SOURCE: water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Posted on Sep 02, 2009
Testimonial: "Thanks for the suggestion. "
Leaking rear white valve at lower back of whirlpool fridge.
Hello is the valve leaking where the water line comes to the top of the valve?
Sep 27, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
WATER DROPS AT TOP OF FRIDGE
sounds like the door was left open,make sure nothing is overhanging on the shelves preventing the door from closing next time send model number
Nov 27, 2009 | Refrigerators
My whirlpool gold side by side refrigerator forms a big peice of ice at the very bottom then the ice ends up melting and goes all over the floor whats wrong?
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
Nov 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water buildup in the fridge, dripping in from the freezer
This could be a bad thermostat. If your thermostat never closes it's swith then the defrost element never comes on and you get the problem you are having. Easy fix. Do you know where your timer is and can you retate it?
Jul 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side freezer not freezing but fridge is running
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Oct 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool fridge will not get cold after cleaning
IF THIS REFRIGERATOR IS A TOP MOUNT FREEZER/REFRIGERATOR, CHECK TO BE SURE THAT THE FILL TUBE AND CUP ON THE BACK OF THE ICE MAKER ISN'T FROZEN UP. THE WATER SHOULD FLOW DOWN THE FILL TUBE, THROUGH THE CUP, AND INTO THE ICE MAKER.
I'M NOT SURE WHICH PANEL YOU REMOVED. IF IT IS THE ACCESS PANEL DOWN AT THE BOTTOM BACK OF THE REFRIGERATOR, THAT IS WHERE THE INLET WATER VALVE IS LOCATED. IF THAT IS WHERE THE WATER IS SQUIRTING FROM, CHECK THE CONNECTIONS ON THE VALVE TO BE SURE THEY ARE TIGHT. ALSO, CHECK THE PLASTIC WATER LINES ATTACHED TO THE VALVE TO BE SURE THEY AREN'T CRACKED OR BROKEN.
Mar 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
85 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
