Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Bosch WET 2820 dryer pumps in water
My bosch WET 2820 pumps in water before it finishes the drying program.
So just before the drying program ends, lets say 10 minutes, it starts to pump in water again.
Might this be solved with a software-reset? Is there a way to completely reset the machines' sofware?
thanks in advance
I have this problem. I also find that every single washing cycle ends with water still inside the machine. I have replaced the drain pump and the drain outlet pipe, checked all the plumbing for blockages.....but still water fails to drain away.
I then have to select a spin cycle which sometimes works but mostly fails. to top off all the problems, just when i think i can dry a few socks the drying cycle pumps water in to the machine.
End up back where i started.....a bucket load of unwashed clothes.
Can anyone help?
  • PaulJPJPJ Nov 11, 2009
    Did you find the fault with this machine. I have exactly the same fault.
    Thanks
    Paul
The problem was the thermostat in the drying inlet chamber. Very easy to get to and very easy to change.
Part No.175369 (NTC sensor)
Regards
PJPJ
Posted on Jan 03, 2010
  • 105 Answers
Sounds to me like a "mother board" of some sort is having a bad day everyday,....call dealer with serial# and model#, date of manufacture (should be one on a bosch) and request any recall info (you never know, you might get a new "brain" for it FREE) or simply ask parts guy/lady if there is a part that is selling with regularity. don't guess with this thing, they are high tech. let me know.
    Champion:
  • 248 Answers
Most likely a electrical fault have programmer checked
Posted on Sep 18, 2009
Machine is locked
Have you tried simply unplugging the machine - that is if you can get to the plug. Or, you could always flip the circuit breaker off. Either way, leave it off for a minute or two, and that should give it time to forget what it was doing. Once you start it back up, it should unlock, unless it has some kind of static memory that survives power outages.
Aug 12, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Hi! re BOSCH washing machine WET 2820 Program will start, and then for 30 secs approx start normally, water starts to enter the drum. Then it stops, nothing happens. I have cleaned the soap dispens
BOSCH washing machine WET 2820 This video will show you how to change the door eal washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 07, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Water leaks in all programs
Bosch WET 2820 Front Load Washer / Dryer water
Leaking.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all bosch repairs in our channel
Feb 27, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Drying cycle - laundry comes out wet!
possibly that drain pump is not pumping out - washer dryers take in water during the dry cycle. check filter
Mar 17, 2007 | Bosch Classixx WVF 240S Front Load Washer...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
261 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
