Question about Husqvarna Prelude 370 Sewing Machine
How to adjust the tension
The top thread is straight, the bottom thread looks as it should
SOURCE: Husqvarna Viking #1plus bobbin problem
I have changed stabalizers and the type of bobbin thread i am using (invisible poly) and it seemd to have solved the problem. Note: wind invisible thread very slowly and carefully it is like fishing line
Posted on Dec 16, 2008
  • 272 Answers
SOURCE: Husqvarna bottom thread showing through the top
On the far left of the machine is the tension wheel for the bobbin. Sounds like it is way too loose. Should automatically set if you have entered the right type of fabric.
Posted on May 08, 2009
  • 192 Answers
SOURCE: MegaQuilter Tension
Try at least 2 new needles first (HLX5, preferably Schmetz). If same, look for any rough edges on the needle plate and feed dog cover.
Beyond that, this does not sound like you are doing anything wrong. You should take your machine in for adjustment by an authorized technician. You should have about 1/2 to 1 full turn of the upper tension knob between too loose/ugly on back and too tight/breaking on the top.
Posted on May 12, 2009
lintalks71
  • 7 Answers
SOURCE: I have a viking designer I and I am trying to embroidery lettering. No matter what I try, it puckers. It looks like the bobbin tension is too tight because I use red thread on top and white on the bot
It sounds like a stabilizer prob. Try some better stabilibers maybe heavier. It may just need the be adjusted by a sewing technician at your local dealer. You can often take these in and have them hooped up and tested right there on the counter. I can do this at my store here in Portland, OR. They usually like them to run well or they get a bad rap. Just try better bobbin thread like anything but YLI. Try a different needle possibly. Or call Gary at 503-254-7317 and ask him what needle to use and what stabilizer and say Lin asked him to assist you. Tell him you are my friend.
Posted on Jun 19, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
Bottom thread is still loose even if i try to balance the tension, how do i balance the thread tension?
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
Apr 15, 2015 | Singer Sewing Machines
Why is the bottom stitch straight
Thread tension is a BALANCE between the top tension and the bottom tension. It appears that your bobbin tension is sightly tighter, causing the top thread to be pulled down. Run a zigzag stitch. If your top looks fine, but your bottom looks something like chicken footprint tracks, see if you can adjust your top tension a little tighter to compensate. If, in doing that the stitches are balanced but just too tight, you will need to adjust your bobbin tension SLIGHTLY looser. You will need a tiny screwdriver to do this. Take the case out and locate two screws on the side. Once is a Phillips--leave it alone. The other next to it is usually on the left of the Phillips, and, is a straight-blade screw. Lefty-loosey, righty-tighty. In your case, you want to adjust it a LITTLE looser to match the top tension--no more than 1/4 turn. Put it back and test it again; you should see some improvement. If it still needs a little adjusting, reinsert and repeat, but ONLY 1/4 turn at a time.
DON'T fool with it at all if you can compensate by tightening your top tension, and before you do anything, clean and oil your bobbin area with ONE drop and ONE only of sewing machine oil.ONLY. You might find that just cleaning and oiling will solve your problem right there.
Jul 06, 2014 | Singer 6038 Mechanical Sewing Machine
Singer xl-400 bobbin tread to loose when momograming
It means that your top thread tension is tighter than your bottom thread, and it's pulling your bobbin thread up. You loosen your top thread by turning the dial towards the "S." You should only have to loosen it by a maximum of one number; if it's more than that, you may have to adjust the bobbin thread tension.
You do that by first turning off the machine and removing the embroidery unit. Turn the tension dial to S. It helps to use a different color top and bottom thread, with the scrap fabric a third color. Run a straight stitch and zigzag stitch and examine them. If one size of the zigzag looks like "chicken tracks" or one side of the straight stitch is a straight line, it means that side is too tight. Take a look at your user's manual on page 11. If your top tension is on "S" and it is the side that is too tight, you will need to tighten the bobbin tension, to match the top tension. Tensions are a BALANCE.
The next step needs to be done systematically and carefully. If you don't, you can really make things worse. Set your mind to doing everything step by step--don't get tempted to jump ahead. Take the needle plate off and take out the bobbin case, and locate two screws on the side. One is a Phillips screw--leave it alone. The other is a straight screw--that's the one, and you will need a tiny screwdriver to adjust it.
The rule is "righty-tighty, lefty-loosey." Remember, you are trying to match the top tension! Give the screw on the case no more than 1/4 turn, reinsert and retest. You should see at least a little improvement. Keep doing that until you have balanced your stitches, and DON'T jump ahead! The difference between too tight or too lose is often a very small turn of that screw--especially when you're close.
Jun 11, 2014 | Singer Sewing Machines
I have a singer 7258 that I can not get the tension to loosen up on. The top stitch is straight across and adjusting dial doesn't help.
Hello
Adjust the tension
Load your sewing machine with one color on top, threaded through the needle. Load the second color thread into the bobbin and thread.
Fold the scrap fabric in half, and sew a straight stitch at least 2 inches long. Look closely at the seam. If you see loops of the bottom color thread on top of the fabric, proceed to Step 3. If you see loops of the top color thread on the bottom of the fabric, proceed to step 4.
Loosen the top tension. Since the top tension is so tight, it is pulling the bottom thread up through the fabric. Loosen the top tension by turning the numbered knob on the front of the sewing machine counterclockwise by one number.
Tighten the top tension. Since the top tension is too loose, the bottom thread is pulling the top thread down through the fabric. Tighten the top tension by turning the numbered knob on the front of the sewing machine clockwise by one number.
Sew a straight stitch 3 inches in length. Check the stitching. It is perfect if the threads meet in the middle, and you can only see the top thread on top and the bottom thread on bottom. If it still needs adjusting, go back to step 2 to repeat the needed steps.
Using two different colored threads makes it easier for you to see which thread is being pulled.
Always use proper precautions when working with electrical machines.
Aug 01, 2011 | Singer Sewing Machines
Thread tension won't adjust properly. Top thread is ok, bottom ,
I could be as simple as threading the machine with the presser foot up.
When the foot is up, the tension opens and accepts the thread. Foot down and thread cannot enter as it should.
Out of control upper thread can look like a bobbin tension problem.
May 19, 2010 | Sewing Machines
How to adjust tension on bottom stitch?
There are tow places where the thread tension is adjusted.
One is bobbin. This is not routinely adjusted. Just once and it is good for long time. This is done by turning the only screw on bobbin by about 1/4 turn or so at a time. Try several settings until you find he best.
the other place is the conventionally on body of the machine.
Tension of bottom stitch or top stitch are very confusing words. meaning difft things to difft pple.
All i can say is this. If u see bottom stitch run straight through loops of top thread. then either top tension is too loose or bottom too tight. and vise versa.
With top tension set to middle position adjust the bobbin to get correct stitch. Then later on all u need is to adjust only the top setting according to stitch and cloth
Oct 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Yet another stitch tension problem...
Thank you, thank you! I just tightened the screw on my bobbin case and that instantly fixed my thread tension problem. How on earth are you supposed to know about the little screw?! I thank you so much for the tip!
Nov 22, 2007 | Euro-Pro Shark 80 - 7133
Husqvarna Prelude 370 Sewing Machine Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
