Question about Garmin Rino 120 2-Way Radio
I don't have a screen display on my Rino 120
I have back light ....no screen...went dead on me on my way out of the woods one night...
5 Suggested Answers
SOURCE: broke rino
I had a similar problem with my account.
I pushed the one batteripolen down as it started up again.
Posted on Aug 09, 2008
bunnydawg
  • 5158 Answers
SOURCE: LED does not work
you have damaged the screen and it will likely need replacement. there is one other possibility... you may have loosened a connector inside the radio... tap it gently with your finger to see if there are any changes in the display
Robert
Posted on Sep 20, 2008
Driver_851
  • 13 Answers
SOURCE: RINO 120 :: screen blanks out with just a single horizontal line
Had to wait 24 hours to be able to post my own answer
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
http://www8.garmin.com/aboutGPS/waas.html
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
Posted on Oct 03, 2008
  • 3 Answers
SOURCE: Rino 120 - Disabled WAAS
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
Posted on Nov 28, 2008
My rino 120 says check wiring under status??
http://support.garmin.com/support/sw/supportPage/display?locale=en_US&topicName=Rino 120
Oct 10, 2015 | Radio Communications
New SKILSAW 5995 used once to cut 1/4 inch plywood, no problem. Several months pass and I went to cut a pine board, the blade touched the wood and stopped. I recharged the batteries and tried again, two...
Did you fully charge both batteries before using them the first time? If not then they may not be able to hold a charge. It sounds to me like the batteries are either dead or defective as obviously the saw now doesn't have the juice to cut the board. If it's still under warranty take it back and get a replacement. Also, how powerful are the batteries? Even an 18V saw will struggle sometimes cutting a 2x4, they just don't have that much power. The plywood is easier to cut obviously.
Aug 12, 2011 | Skil Saws
I HAVE A GARMIN RINO 120 AND THE BATTERIES GO DEAD VERY QUICKLY. YOU CAN USE IT OUNCE TURN IT OFF AND THE NEXT TIME YOU USE IT THE BATTERIES ARE ALMOST DEAD.ALSO IT LOSES SATELITE SIGNALS AND TAKES A LONG...
An older unit. No service available from Garmin as it is obsolete. The 120's have a lot of problems. Poor battery life. Poor reboot and constant dying after on. I would find another unit.
Aug 10, 2017 | Garmin Rino 120 GPS Receiver
Waypoint selection uses last location instead of current location
Backup all data and reset the unit. Hope this helps...
Jan 14, 2009 | Garmin Rino 120 2-Way Radio
Oct 04, 2008 | Garmin Rino 120 2-Way Radio
LED does not work
Robert
Sep 20, 2008 | Garmin Rino 120 2-Way Radio
Turn it on - black screen
Dropped the rino 120 and the led is blank but radio works
Sep 01, 2008 | Garmin Rino 120 2-Way Radio
Broke rino
Mar 12, 2008 | Garmin Rino 120 2-Way Radio
Garmin 120 just dies
hi
have you put fresh batteries in
are they the right way around
are the 2 metal spring clips tight up against the batteries
try bending them (al little) to make better contact
has the unit had any water in/on it
is the mic button pushed down and draining the batteries too quickly
D
Nov 21, 2007 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
Top Garmin Radio Communications Experts
eradiostore
eradiostore
Steve
Computer Repairing
Computer Repairing
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
