Question about Sony Handycam CCD-TR913E Camcorder
I HAVE A SONY 8MM HI 8 CAMCORDER MODEL # CCD-TR91. I CAN PLAYBACK THE CASSETTE ON THE CAMERA AND SEE IAND HEAR IT IN THE VIEWFINDER. BUT THE PICTURE IS DISTORTED WHEN I TRY TO PLAY IT THROUGH THE TV.
philipp
  • 217 Answers
SOURCE: cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Posted on Sep 15, 2007
SOURCE: fuzzy picture
The tape is not adjusted to cylinder head. Both the sound and picture is lost when the tape is not exact on the wheel (head). If the camera has not been used for a long time then can the adjustable pins start to rotate and change the position of the tape when it is used again. The oil has dried out and the pin is not running smoothly, and the screw starts to rotate as well.
So, the solution.
a) remove the plastic cover so you can see the two pins that pulls out the tape from the cassette.
b ) small droop of oil on the top of the two pins
c ) use a small screwdriver to change positions of the tape, by turning screw on the top of the pins.
Put in the tape again and test , thus you have to do small adjustments. Repeat the test until you see the picture.
This is simple but it will take some time. I have now saved all old films, it is hard to find a old video-8 analog camera ....
/U
Posted on Jan 30, 2009
SOURCE: Sony TRV510-playback, audio choppy, image isn't clear
I did the 2nd solution by recording 15 seconds on a brand new tape and then when I put the other 8mm tape back in it worked and sounded perfectly! The sony website quoted me $311 to fix my camcorder and all I had to do was that! Thanks so much for the idea!
Posted on Feb 09, 2009
welcomejee
  • 10594 Answers
SOURCE: Problem with Sony CCD TRV138 camcorder
Symptom shows bad CCD IMAGER in camera and requires replacement. (IC951 on CD-465 board, mounted at end of lens mechanism).
Nice to know that you are tech person so buy CCD IMAGER from any part store under following part number..
A-7013-219-A CCD BLOCK ASSY (CCD IMAGER) (TRV138/TRV338)
Good luck.
Posted on Mar 15, 2009
SOURCE: Rolling of picture
I have a Handycam Video 8 CCD AF camera. I bought it in about 1993. The picture I'm getting is very fragmented, jumpy, and for them most part lacking color. I can barely see the images because of all the jumpiness. How do I fix this???
Posted on Dec 23, 2009
I had an old Sony CCD-TR940 Hi 8. It died. I still ike to view the 8mm cassette and transfer them to my PC. Is there an equipment that can only view these cassettes I live in Bangkok
i can only suggest on getting a not so expensive camera so that you can do the task you wish to do
try e-bay http://photography.shop.ebay.com/Camcorders-/11724/i.html?_nkw=hi+8&_catref=1&_fln=1&_trksid=p3286.c0.m282
hope this help feel free to rate
May 05, 2010 | Sony Handycam CCD-TR940 Camcorder
Does sony ccdtrv12 camers use normal 8mm or hi8mm
CCD-TRV12 needs standard 8MM tape, it is not Hi-8 camcorder.
Thanks.
Mar 03, 2010 | Sony Handycam CCD-TRV12 Camcorder
My tape deck on an old CCD-TR91 Camera will not go down when an 8 mm tape is placed in it. Consequently, I cannot upgrade my home videos to DVDs. Any suggestions?
When you got your camera, did you receive a VCR adapter that you can put the 8mm in and then pop it into your VCR?
It will be pretty spendy to have somebody do it for you if you want it done professionaly.
I hope thisw helps.
Oct 25, 2009 | Sony Handycam CCD-TRV87 Camcorder
Sony handycam video cassette
To the best of my knowledge 8mm VTR's have not been available for some time now. On the other hand there are plenty of Hi8 cameras and players available after market. eBay is a great source. Keep in mind that Hi8 cameras and decks will also play standard 8mm video tapes.
There are also many video tape transfer services that will transfer your 8mm tapes to DVD or other formats of your choice. Just Google "videotape transfer service"
Aug 28, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Good luck.
Mar 15, 2009 | Sony Hi8 CCD-TRV138 Camcorder
My sony handycam was stolen how do i play back my 8mm tapes is there an adaptor available?
No adaptor for 8mm tapes. You need to have Sony camcorder or video-8 player for playback these tapes.
Feb 21, 2009 | Sony Handycam CCD-TRV87 Camcorder
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Video Cameras Logo
46 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
