Question about Samsung PN58C8000 TV
The upper right third of my samsung PN58C800YF screen is starting to turn purple when displaying white images, across all devices
The upper right third of my samsung PN58C800 YF is starting to turn purplewhen displaying white images, across all devices
  • 274 Answers
SOURCE: Blue shading problem
2 months old? I'd call the dealer..it's under warentee. You have a problem that will not get better.
Posted on Jul 14, 2007
buBruce
  • 14 Answers
SOURCE: purple bars across the screen?
Unfortunatly This is a manafuctaurer defect. your panel is bad and will need to be replaced by a technician. I know it isnt want you wanted to hear but the F modelf year for samsung is very bad for this. beinf the 61F, 65F, and the 71F. Hopefully you are in the return policy still for the TV
Posted on May 31, 2008
SOURCE: Number 2 in upper right hand corner of screen
Had this problem also when I rebooted my Time Warner Cable box. Unplug everything from the wall including power strip and wait 60 seconds then plug back in and turn everything back on. Worked for me and havent had a problem since. Time Warner does not know what causes this yet.
Posted on Feb 01, 2009
  • 175 Answers
SOURCE: Purple blotch on screen
hi..This patch can be a result of your TV 's Auto Degaussing
Coil problem. Metallic parts of a TV gets magnetized and the
ADG coil demagnetizes them. At power on you should hear a
sound,which is the ADG coil.please check the ADG coil connector
it might have been pulled out. The ADG coil is wrapped around securely
on your TV's Picture tube and power is tapped directly from the AC
Main via a plug in type connector to the TV main circuit board.
check it out..
thank u..
rate me..
Posted on May 04, 2009
roety
  • 585 Answers
SOURCE: Samsung LNS4041DX/XAA White horizontal lines
Hi my name is Roety,
I can help you with your issue ,
If the lines are present on every input you most likely have a bad screen. We usually replace the mainboard first because its cheaper .
Check part prices at encompass.com login as a guest
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Dec 01, 2009
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
Purple patches across top third of screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 09, 2015 | Samsung PN51D530 51 in. Plasma HDTV
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
Can't bring into focus the entire image. Corners defocused and have green/purple halos.
If it is a known problem, then it is a manufacturing error. They have just admitted that is a MISPLACED washer. Have Optima repair it free of charge.
Mar 28, 2017 | Optoma Office Equipment & Supplies
LG L194WT picture problem
Sounds like your main board is going out. It's cheaper to buy another monitor then fixing it unless you have a warranty.
Feb 18, 2013 | LG L194WT 19" LCD Monitor
Samsung 32" LED TV Purple Line Horizontally across top of screen
Can you please change the input device to some other you know, works? If you do not notice any problem there, look for the aerial cable going close to any power line or has interference from some other transmissions of any kind nearby.
Jul 30, 2012 | Samsung Televison & Video
Blocks of Colour displaying
 This tv has severe problems in the image processor - you bought a dud. Try getting your money back.
Jun 26, 2010 | Samsung Televison & Video
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung PN58C8000 TV Logo
43 people viewed this question
Henry  Thomas
Henry Thomas
