Question about Bose Wave Radio
Connecting a kindle fire to a bose wave radio
What cable do I need
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
SOURCE: replace fuse Bose Wave Radio
For the AWR1-1W turn it over and there are 4 screws that you must remove. When your looking at the circuit board the fuse is just below the power supply and back of radio. If the radio makes a ‘POP’ sound when you unplug it may not be the fuse as power is getting past the fuse. I have the same trouble with mine. I called BOSE Tech and he said if it makes that ‘POP’ sound after unplugging it is not fuse or power supply. They will not even allow me to send it in for repairs as the radio is over 15 years old and considered unserviceable.
Maybe someone else can give us a quick fix.
Posted on May 06, 2008
  • 20 Answers
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Posted on Dec 31, 2008
BillB-SA
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
DigidocTN
  • 22 Answers
SOURCE: Bose wave radio will not power on. used to work
I repaired mine recently. Check transistor Q4 for an e-b short. The replacement costs less than $1.
Posted on Jun 27, 2009
Bose Wave Radio/Kindle Fire
Yes, all you need is a standard audio adapter cable that plugs into the earbud jack on the kindle and into the "variable in" jacks on the back of the Bose. (male stereo 1/8" plug to a pair of male RCA/phono plugs).
Dec 11, 2013 | Bose Black Wave Am/fm Radio W/ Remote -...
Tip
How to connect an iPod to my Bose Radio
<p>The manufacturer offers two radios Bose iPod connection kit to connect an iPod to the radio. You can purchase the kit to connect the wave or acoustic wave connect kit. Both kits come with a USB audio connection, an iPod dock for iPod, a battery that plugs into the wall and a remote control to use the iPod while in dock. Download all the upgrades to your iPod through Apple's website before connecting a Bose radio. <br /> <p><br /> <p>1. Connect one end of the audio cable is included with the connection kit for iPod "Aux In" on the back of the Bose radio. <br /> <p><br /> <p>2. Connect the other end of the audio cable to the "Audio Out" on the back of the iPod dock. <br /> <p><br /> <p>3. Connect the adapter to an outlet connection kit. Connect the other end of the battery to the "DC Power" on the back of the iPod dock. <br /> <p><br /> <p>4. Set the iPod dock on the right side of the face of Bose radio out. Align the IR sensor on the front of the iPod dock with the IR sensor on the front of the Bose radio. <br /> <p><br /> <p>5. Place the iPod firmly in iPod dock. Point the remote at the IR sensor, iPod dock. Press the "iPod" for the iPod <br />
on Aug 09, 2011 | Apple iPod touch
I have a ten year old bose wave/radio/cd player. Sound is great but want to play music from my ipod through the bose. my ipod plays in car using aux cable but this does not have same result when...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
Jun 17, 2011 | Bose Wave Radio
What does the BoseLink input do? Can I use it to connect my Bose Radio to my HD TV? It has a USB port for audio sound output. (I can't seem to find the manual that came with my Bose Radio)
yes, buy a 3.5mm to 3.5mm cable. It looks like a headphone jack on both ends. Plug one end into headphone jack of HDTV and plug the other end into the 3.5mm Audio In jack on the Bose Wave. Boselink input is for other Bose components.
Mar 02, 2011 | Bose Wave Radio
Can you connect two Bose Wave radios together for more sound volume?
There are several types of Bose Wave Radios - the one pictured (the others likely do, too) have "Line Out" and "Aux In" jacks. Each consists of a Left and Right pair of RCA type jacks. Simply connect the "Line Out" jacks of one of the radios to the "Aux In" jacks of the other. Select the "Aux" source of the radio that has the cable connected to the Aux In jacks. Whatever is playing on the main radio (CD, Tuner, or other input) will be heard on the second radio - if the Aux source is selected.
Please rate this reply if it was found to be helpful - good luck!
Jul 03, 2010 | Bose Wave Radio
Would like to connect Bose Acoustic Wave II sustem
If your TV have audio output ( RCA or any kind ) then you can hook that up ( you can buy the cable from radio shack ) then to BOSE audio input w/c is the AUX input.
Apr 26, 2010 | Bose Wave Radio
I want to have TV sound come thru myBose Radio what connections do I need and where to connect
Assuming there's stereo rca outputs on the back of your tv, you just need an rca audio cable to run from the output of your tv to the input on your Bose.
Aug 02, 2009 | Bose Wave Radio
Unable to connect ipod
Reset the radio (it has a processor) by just unplugging the power cord for about 30+ seconds and plugging it back in. If this doesn't solve the problem, try replacing the remote battery (CR2032- can be found almost everywhere batteries are sold) If all else fails, call Bose tech support. The cable you connected has nothing to do with this.
May 09, 2009 | Bose Wave Radio II
Bose wave no sound
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. According to their web site, www.bose.com, they will repair most Wave radios for $100 or give you $200 credit towards the purchase of a new set. Check your options before you spend the big bucks though. A new HD radio, with better sound and a MUCH lower price, might be a better choice than repair of a problem prone Bose.
Bill B.
Jan 26, 2009 | Bose Wave Radio
Bose Wave Radio Logo
423 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
