Question about Jenn-Air JGR8875QDS Gas Kitchen Range
I have a kitchen aid stove gas stove top.had a pro longed power outage(24 hrs) will not ignite auto matically any more must use matches.any suggestions?
  • Anonymous Mar 23, 2014
    replaced 4 times substitution
    for kitchen aid if any
    President:
  • Jenn-Air Master
  • 2,651 Answers
Check the outlet, perhaps it's its hokked to a GFI outlet somewhere else in the kitchen and the GFI outlet has tripped
Posted on Jan 11, 2009
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
How to light the pilot on my stove top
Most stoves with pilots the gas is blowing all the time out the pilot. If you can find it take a long match or a barbecue lighter and hold close to the pilot itself and if you ignite the burner its self with a match some times it will ignite itself if you are lucky. Some times you can take the cover off the burner to get to it.
Oct 20, 2014 | Kenmore Kitchen Ranges
Brown gas range auto ignition not working
If the problem is with all the burners then the igniter module may be defective. If this is happening only with some burners then the cable to the ignition point has become loose or is shorting with the body.
I am assuming the model number is correct but I am not finding any details for this 24 inch freestanding gas range. If the oven is electric and if it is running that means at least the electric power is reaching the unit.
Brown Stove Works INC
The oven parts are available here
Brown Range Stove Oven Parts
Sep 03, 2014 | Brown Stove Works TM110-3 Gas Kitchen...
Tappan gas stove
Older gas stoves used a battery to ignite the flame but due to its age, I would get a hand held gas lighter.
Apr 21, 2017 | Kitchen Ranges
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
I have to use a match to light the stove top and the oven doesn't work either.
what i believe is if power is on to stove,the igniter work off of electric and espically if no power to range the oven will not work
Aug 22, 2011 | DCS RGS-305 Professional Gas Kitchen Range
How to use kenmore gas range during power outage
just use a match to light top burners, the oven will not work or pass gas if you have a electronic ignition range
Feb 06, 2010 | Kitchen Ranges
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
I have a used kenmore propane gas stove that i just bought from someone. We have hooked it up but can only get the oven to come on. The stove top burners will not come on. We we turn on the burners we do...
In the old days stoves were lit with a match. If this does not work for you it would be due to the stove's lines remaining "airlogged" after the move. The oven purged and ignited more easily because it has a much larger orifice, so the air bled more quickly. I expect if you were to leave one burner turned on long enough for the air to bleed out you will find it to ignite normally. Do not leave the stove to bleed unattended, and if you encounter a strong smell of the gas, turn off the burner, and ventilate the room as needed. The smell of gas would indicate that gas is present, it may be possible that a lead came disconnected from the ignition module in the back of the stove. Again if this is the case, the ol' match will light the burner. Be Careful!
Dec 14, 2008 | Garland H283 Gas Kitchen Range
Jenn-Air JGR8875QDS Gas Kitchen Range Logo
195 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
