Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Primea ring hot milk
Hello, im sorry to bother you but iam having trouble with the machine and you seem to know what you are talking about, the milk is only luke warm and i see you have posted how to get into the service menu ,could you run through the instructions to make the milk hotter , i have got in the service menu but dont know what to press and how to change the settings, i dont what to just press anything, the coffee waste is wet not like a hockey puck, hope you can help, thank you for your time
  • holmeswafc18 Jan 11, 2009
    hello again, thank you so much for the advice , i will try your settings , only had the machine for 2 days , if the settings make the milk pipping hot this would be 1 of my better buys,,i was going to get a jura f90 but i wanted a machine that frothed the milk for you for ease of use, thank you so much for your time,regards gareth
  • 0505 May 11, 2010
    Hello! I can give you my settings. But first i would like to recomend to add only water in your milk container and press for hot milk, try that with two full containers with fresh water and see if it´setting warmer and warmer after each time you press for hot milk. As im from Sweden i will give you my temp settings in Celsius. Activated water temp 135C, Deavtivated 115C. Avctivated Steam temp 145C Deactivated 135. Normal cup temp 96C. Do some fine tuning on your machine and you will soon find your perfect settings. Write down everything before you make any changes. And with 96C cup temp. You´re coffie will be damn hot! I have set my brew grinder to 95 impulses with aroma. That setting adds more coffie for each portion. If your machine hangs up while doing changes, there is no problems at all. Just restart and change to less impulses. You will notice that all coffie beans are not the same. So if the type of beans you use now work fine with 95 impulses, it dose not mean it will work with the next type you buy. But soon you will find and neutral setting for all type of beans you like! I guess that more impulses will give you the hockey puck like coffie sump.
    Problem Solver:
  • 5 Answers
Remember that the milk temp should be around 60-70c. Milk will start to boil around 80c.
You´re welcome and good luck!
Posted on Jan 11, 2009
Milk frothing is very poor. I have had the machine for 7months and at the moment the frothing has stopped and milk is warm not hot. I have tried to adjust the frothing with the white wheel bu it doesnt...
Hi. Have you removed the white wheel and tried to clean it? Check the O-rings on the frothing part for damages.
Sometimes cleaning it hasnt helped at all, The solution for it that might sound crazy =) that fixed it for me at that time was to block the 2 holes with you fingers(be carefull its hot) where the milk comes out from when you make coffee, you get a little backpressure in the milk circuit when doing it. Try 2 or more times. It helpt me.
Oct 18, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
if you go in the menu there a temperature setting for that machine pierre
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Touch plus
Hi There,
First I would like to say a very big THANK YOU.
For taking time to post a solution, thank you so much.
I can enter both service menu!
I change the "Milk Steam Temp." to 150 degrees, and "coffee Temp" to 83 degrees.
All appears to be working fine now and I am very happy !!!
Thank you again for all you help. Your English is great too :-)
Jul 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Ring - no milk - just steam
Hello!!
Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
But there is a service menu on primea touch plus series.
Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
Okay, to enter the menus you have to turn you machines off.
Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
Let me know some results please!!
Apr 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring - milk not hot
Hello!!
Mar 04, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
320 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
