How do i bleed an efel oil stove
Ran out of oil
2 Suggested Answers
SOURCE: having trouble lighting a second
plug in, open bottom and clean line end by twisting and pulling pushrod, make sure valves are on, tank must be higher do to gravity feed, crack open door 1/2 in, turn timer dial (one that clicks) all the way it should glow at bottom of crown, turn on fuel to low setting (just counter clock of the click), once flame is burning across the bottom of the pan close door all the way. The door open is so that it keeps stove clean for lighting also open the door for closing. If smoke is coming out of the door close it a little more. the stove needs to be clean and will stay clean for a long time if you open the doors. if it floods you need to clean it out. there are fuel adjust screws and air adjust counter weight but have a professional set those. good luck its a great stove once you get to know it.
Posted on Oct 25, 2010
Efel oil stove wont burn blue only yellow
Pull the crown and the two crown supports, scrape and vacuum the residual ash on the bottom and around the starter coil. Pull the and turn the oil feed tube scraper back out of the way. Reach inside the tube with a screwdriver and scrape out the residue until as clean as posssible. Exercise the fuel tube rod several times until there is no scraping sound. Vacuum the interior and replace the parts (Do not clean the crown).
Dec 23, 2012 | Cars & Trucks
Furnace ran out of oil,got oil for the furnace,started furnace ran for 10 secends then switched off
On the oil pump there should be a bleed screw. Attach a tube to it and the other end to a can and 3/8" wrench, restart burner by depressing red button on Honeywell control and open up bleed screw. Oil will start flowing into can. When full stream of oil coming out of hose, tighten bleed screw. You have less than a minute to do this or the Honeywell control will shut off burner for a minute. It may take more than one try.
Jan 18, 2011 | Heating & Cooling
I have an old Efel Kamina wood stove that I want to install in a new structure that does not have a chimney. I need the manufacturer's specifications to determine the distances from combustible materials...
From an insulated wall - 30 inches. Not insulated - 38. We have one as well and are trying to find out information about it.
Southport Stove Inc. Serial # F90309 ICBO 3 500 Another number: 079-66 It's a Kamina.
Any information would be great!
Sep 14, 2010 | Heating & Cooling
Having trouble lighting a second hand efel oil stove what is the steps needed to take when igniting it
Sep 13, 2010 | Heating & Cooling
Heating & Cooling Logo
239 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
