Question about Seiko Coutura Watches
My grandson broke (don't ask!) the band off of his Seiko 7T04, leaving no links at one side of the case and 1 link attached to the other side. Can this be repaired at home?
The band (bracelet) was broken away from the watch case, leaving 1 link still attached on one side of the case and no links attached on the other side. The watch is physically undamaged and keeps time. All functions seem to work. I would like to reattach the bracelet w/o sending the watch off for repair. Is this possible at home and, if so, what do I need. I do have two "split" pins that were left over after a link was removed from the band for resizing.
    Top Expert:
  • Seiko Master
  • 78,238 Answers
No you need to seek the help of a local jewelry shop.
Posted on Jun 15, 2017
SOURCE: watch band repair
Cleaning yellow Nautica plastic or rubber wach bands
Posted on Oct 15, 2007
  • 67 Answers
SOURCE: removing watch links
Look at both ends of the pin. One will look smooth, the other appears split.
You will need a suitable soft (wooden) support, and a very small dia. punch and a light hammer. The rest of the watch can be protected with a soft cloth.
You place the punch on the end of the pin which looks split, after arranging the watch so the link you are driving the pin from is supported on the edge of the timber. I drill a hole close to the edge of the timber over which I place the pin to be removed. Then by gently tapping the punch with the hammer, the pin should slide down into the hole.
One pin needs to be removed completely, the other can be left in the next link ready to tap back in after the link you wish out is removed.
The important thing is to have a decent punch! The diameter must be such as to fit easily through the pin holes, and the end should be flat. If you cannot make or find a suitable punch, one could be made from something like a darning needle.
Posted on Feb 22, 2008
SOURCE: Armitron mens watch band link removal
Try http://www.webjeweller.com/jewellery/removelinks.shtml
Posted on Jul 14, 2008
escapement
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
escapement
  • 2334 Answers
SOURCE: how to resize (remove links) from metal band on casio wtg900da8v
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Mar 21, 2009
Link removal from bracelet?
    1. Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
      Remove the Link Bracelet on your Apple Watch - Apple ...
      https://support.apple.com/en-us/HT204831 Apple Inc.
    Feedback
  1. How to resize or remove links from your Magnetic Bracelet ...
Jan 01, 2016 | Watches
How do I remove links from a Seiko watch band?
Follow these steps and it will help u resize your watch.
1-Take a good look at the watch bracelet. Seiko watch bands are equipped with one of two different types of pins holding the links in place. One type is a simple, nail-shaped pushpin that's inserted into the joint between two links. The second is a flat, L-shaped piece of metal that slides into the center of a link and locks it into place. Both pins are removed using the same process. If the nail-shaped pushpin is present, you'll see the tiny screw heads in the joints. If the L-shaped pin is present, the links will be open-sided and you'll be able to see a strip of metal inserted in each links.
2-
Look for the arrows on the inside of the watch bracelet links. The arrows indicate the direction the pins and links need to be slid off of the band. Any attempt to go against the arrows could break or warp the links.
3-Remove the spring bar from the clasp with the small pin-removal tool. Set the watch up on it's side so that the top of the spring bar is facing up and the bottom is flush against the table. Put moderate pressure on the top of the spring bar and tilt the watch just a bit sideways so that the spring bar can slide out. Ease out the bar slowly and carefully; the spring bar is spring-loaded and will shoot away from the watch if you're not careful (make sure that the bottom of the watch is pointed away from you at all times). Put the spring bar in a small dish so it doesn't get lost.
4-Line up a small pin-removal tool with the top of the pin and push in the direction of the arrow until it slides out completely. Slide off the link. Place the pin and the link in the small dish. You'll want to save them in case the watch needs to be re-sized again at a later date. Continue removing links, alternating sides of the band to keep it even, until the watch reaches the desired size.
5-Reconnect the watch. On the side opposite where the spring bar was removed, line up the link connected to the clasp and the second link on the band. Slide the pin in the opposite direction of the arrow, using a flat-headed pin inserter to push it into the joint. Use the pin-removal tool to give it a final push, listening for the click.
6-
Reinsert the spring bar slowly, using the pin inserter. Make sure the spring bar is lined up and tightly in place to avoid injury.
Try this and it you cant manage it then you need to get it to a watch repair shop specializing in that brand.
Jan 09, 2011 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
Where are the model number and serial number on a rolex
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    Shorten the band on a Mossimo watch
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
      Making the Band Shorter
    1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
    2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
    3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
    4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
    5. Making the Band Longer
    6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
    7. Step 2 Push the pin out so the link is detached from the clasp.
    8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
    9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
    10. Step 5 Repeat this process if you need to attach more than one link.
    Aug 14, 2010 | Citizen Watches
    After buying this model watch bracelet links are rusted and torn with one year of purchasing. When i took that watch to the show room where i purchased. They kept it for 40 days saying that they has to...
    mcdevito75 here, Many watches built today are not comming out with replacement Bands (straps, Bracelets) from the factory, the cost of makeing and keeping extra bands on hand is too high, they should at least have a few extra links to replace worn ones. Chances are your warantee is over on the watch and in that case, you"ll have to find another band, Bracelet on your own. Best Bet, visit a small watch repair shop in your area for another bracelet, band, Strap.
    Jun 29, 2010 | Watches
    Need pin for band on Fossil Am 3754
    Measure distance between the lugs of your watch. Find the nearest watchmaker and ask for spring lug of that size (this is if you need to attach band to watch).
    If you need a pin for bracelet links- measure width of bracelet and ask for split pin of that size.
    Dec 18, 2008 | Fossil Watches
    Link removal
    here are the steps SEARCH Watches Jewellery WATCHES JEWELLERY GIFT CENTER FEATURED ITEMS WATCH SPECIALS GIFT CERTIFICATES WHAT'S NEW HOME EN FRANCAIS ORDER TRACKING CURRENCY CONVERTER ABOUT US CONTACT US HELP How to Remove Watch Links The following method outlines how to remove most watch links. If you have any questions, please send us an email at Info@Webjeweller.com 1. Pin Type I 2. Leaf Spring Coupled Type 3.Single Screw Link Type 4.Snap Type 5.Bracelet Sizing Instructions 1. Pin Type I (Tools: Eyeleteer, Staking stand, Hammer or Pliers) Step 1. Set the watchband onto a staking stand or other appropriate holder. Step 2. Use an eyeleteer to push out the watchband connecting pin toward the arrow. If the pin is too tight, use a hammer to lightly tap out the pin. Step 3. Pull out the connecting pin with a pair of pliers. Step 4. The selected link can be disconnected from the adjoining link. 2. Leaf Spring Coupled Type (Tools: Tweezers or Pliers) Step 1. Use a pair of tweezers to push out the leaf spring of the link in the direction of the arrow. Step 2. Remove the leaf spring by using a pair of pliers. Step 3. Other types of leaf springs as illustrated above are also used in leaf Spring Coupled Type Watchbands. Step 4. Disconnect the link from its adjoining link. 3.Single Screw Link Type (Tools: 1-mm Screwdriver or Tweezers) Disassembly Step 1. Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side. Assembly Step 1. Reassembly is opposite of disassembly. Assemble the link, and turn the bracelet on its side. Insert the screw into the link either with a pair of tweezers or your fingers. The screw will only go into one side of the link. Step 2. With the bracelet still on its side, securely hold the bracelet between your fingers, and place the 1-mm screwdriver tip into the screw slot on the end of the screw. While using gentle downward pressure on the screwdriver, turn the screw in a clockwise direction until you feel the screw stop and the top of the screw is just below the edge of the edge of the bracelet. Do not apply more than gentle pressure on the screwdriver as it could cause the screwdriver tip to slip off the screw end, which may scratch the side of the bracelet. Step 3. Once the screw is screwed down in the link as fare as it will go, give the screwdriver one final"twist" to securely tighten the screw. Be careful not to use too much force as the screw head could become damaged. 4.Snap Type (Citizen Sizing Tool) Step 1. Remove the link pine in the direction of the arrow. Step 2. Grasp the band on either side of the link from which the pin was removed. Apply gentle upward pressure on the side nearest the case, while applying gentle downward pressure on the clasp side of the band. You will feel mechanism disengage. Step 3. While continuing to apply gentle pressure as outlined in the previous step, gently"rock" the band to completely release the mechainism. Step 4. After releasing the mechanism move the clasp side of the bracelet towards the case to dissemble the links. Step 5. Gently pull the links apart. Repeat the procedure for as many links as need removing. Reassembly is opposite of disassembly. 5.Bracelet Sizing Instructions (Tools: Citizen Blue Pin Pusher Link Joint Remover II or Tweezers) Link Components 1) Split Pipe -Two pieces, one at each end of the pin. Generally one split pipe will remain attached to pin during sizing. 2) Cylinder Link - Two pieces, one at each side of the bracelet link. 3) Link Pin - Connects link, cylinders and split pipes together. Step 1. Note the engraved arrow on the backside of the bracelet showing the direction in which the link pin should be pushed and lay the bracelet in the cradle as shown above. Align the pin of the pin pusher with the link pin, being careful to centre it. Once centreed?, apply slight pressure until you feel the pin begin to move and then turn fixture upright as shown in illustration . This slight pressure will keep the pin pusher in alignment with the link pin while the tool is being turned upright. Step 2. With the fixture standing in the upright position, apply even pressure to the pin pusher until the pin drops out. Step 3. Using the tweezers, set the pin/split pipe assembly and cylinder aside. If the cylinder comes off of the pin, reassemble the cylinder and pin. The split pipe for the link pin at this outside end is still on the pin and dose not need to be removed. To reassemble pin and cylinder, insert pin into the hole of the cylinder so that the split pipe rests in the recess of the cylinder. Set aside for use during reassembly of the bracelet. HOME TESTIMONIALS LEGAL NOTICE ORDER TRACKING F. A.Q'S REQUEST A WATCH ABOUT US CONTACT US En Fran?ais | Advertising Opportunities | Affiliate Program | Watches | Jewellery | Diamonds | Feedback | What's New Watch Search | Jewellery Search | Volume Pricing | Request a Watch | Specials | Privacy and Security | Site Map WebJeweller.com, Email: Info@WebJeweller.com Copyright © 1999-2006 webjeweller.com. All rights reserved.
    Aug 10, 2007 | Fossil AM3425 Wrist Watch
    Watches Logo
    35 people viewed this question
    Top Seiko Watches Experts
    Jerry Greenberg
    Jerry Greenberg
    just-ice
    Are you a Seiko Watch Expert? Answer questions, earn points and help others
