Question about RCA L46WD22 Television
Unusable signal on basic video out puts and no sound on any
I do not get a picture on any connection that goes through the basic video connections such as video1 or video2, also there in no sound on any channel. I do get a picture if i run the signal the the component video connection. I did shut of the tv and unplugged it for 20 minutes. Is there a fix for this problem?
  • 24 Answers
Sounds like a bad video (signal board) .Lots or problems with these on this model.Also, hard to replace.If in warranty find an experienced and authorized RCA service center.
Posted on Jan 11, 2009
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Unusable signal is being displayed on television although it is connect to a digital cable box. It gives the same error even when connected to an analog cable box
You will need to have the tuner checked out, try connecting your cable box using the audio/video inputs to your tv(vid1, vid2 etc.)it should give you a normal picture.
Jan 18, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Error on screen showing 'unusable signal' - input probs
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | RCA HD52W58 52" TV
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
No picyure
you havent connected the av leads properly,red and white are for sound and should go from audio out on tv to audio in on sound system,
yellow lead is for picture (aka video) goes video out on dvd player.to video in on TV
basically you need sent video signal from......to
normally have to use AV inputs,so u need turn telle to AV1 or 2
Jul 07, 2008 | Durabrand STS92 System
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
Picture goes out, sound stays on
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Jan 20, 2007 | RCA 27R411T 27" TV
RCA L46WD22 Television Logo
265 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
