Question about HP Photosmart R707 Digital Camera
What to do, I forgot to put memory card in HP R707?
The images are on the camera's internal memory. Can I put the memory card back in the camera and will the pics transfer on? I have a new laptop and no longer have the original HP software on. I just put the memory card in the computer to transfer images, so that is why I need to find out how to get the images on the memory card.
    Genius:
  • 1,447 Answers
Hi
Do you want the pictures transferred to your memory card? that depends on the option available on the camera, try inserting the memory card. select a picture then check options if you can move it to a memory card. if not, download it to a computer and transfer it to the memory card folder.
Hope this help
Posted on Jan 11, 2009
Hewlett packard photosmart r707 card is unreadable
Replace the card. Make sure you back it up to your hard drive frequently.
Mar 05, 2016 | HP Photosmart R707 Digital Camera
My hp photosmart r707 keeps saying the card is unreadable, buti just used it yesterday. i cant reset it either. it wont let me and the computer wont read it
Sounds like you're connecting things like your camera or your card in a card reader and just yanking them out of your computer without using the "safely remove hardware" icon at the bottom right of your computer screen.
Feb 06, 2010 | HP Photosmart R707 Digital Camera
Both the battery and the memory card are "stuck" and wont' come out. We took it to a camera shop with no success.
Put the camera in the freezer for a couple of minutes. If you manage to remove the battery and memory card, wait for couple of hours so the condensation evaporates. After that you will need to clean the contacts for battery and memory card.
Jan 23, 2010 | HP Photosmart R707 Digital Camera
My HP Photosmart R707 Camera not reading memory cards
If the memory card you are using is an SDHC designated card, your camera is probably not compatible with it. SDHC cards are usually 4gb and larger. Check the card for the SDHC label.
Apr 04, 2009 | HP Cameras
Memory card
To transfer the photos, connect directly SD card to your PC through a card reader.
Try to reset your HP R707 camera: remove the battery and press the reset switch for about 5 seconds. Reinsert the battery.
Mar 26, 2009 | HP Photosmart R707 Digital Camera
Menory card unreadable etc.
ok check the card slot for the memory card the pins are bent... for shore
Sep 03, 2008 | HP Photosmart R707 Digital Camera
Card Locked
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Nov 04, 2007 | HP Photosmart R707 Digital Camera
Memory drive
This has happened to my wife's camera twice now. The solution (I think this is the fix) is to take the card out of the camera and then turn it back on without the card in the camera. Doing this will access the camera's internal memory and at this point you should delete any/all/some of the pictures that you find. After deleting some pics from the camera then take a picture. Now turn the camera off and replace the card. Power on the camera and either format the card or just start taking pictures again. I formatted the this last time since I had already moved the pictures to the P.C. and saved them. Give this a try. It's worked for me and it's free.
Oct 09, 2007 | HP Photosmart R707 Digital Camera
Flash problem HP R707
I've just spent 30 minutes on the phone (premium rate) to HP re this problem. The solution was as follows: switch the camera off take the battery and any memory cards out press the end of a paperclip into a small hole (which you can see with the battery compartment open) remove the paperclip after 10 seconds put the battery and memory card back in and the problem should be sorted. HP also suggest upgrading the camera firmware (which you can do via their website)
Aug 10, 2006 | HP Photosmart R707 Digital Camera
HP Photosmart R707 Digital Camera Logo
141 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
