Question about Whirlpool Duet GHW9150P Front Load Washer
Door sensor broken?
My 13 year old and 10 year old girls decided to stuff a king down comforter, 2 king sheets and 2 twin down comforters in the wash and when it wouldn?t fit they sat on the floor of the laundry room and used their feet to make the door close. Now, the machine will not activate. It does turn on and let you choose options but the light on the cycle choice blinks and when you press start noting happens. After checking the basket nothing was off track and opening and closing the door gently I believe that the sensor that tells it when the door is closed is broken. The door closes fine. I have tried doing the manual control lock but it still won?t start. Any ideas??? If I am right and I need to replace the door sensor? does anyone know how to do that? Thanks for any help you guys!!!
  • 5,911 Answers
Sounds like you, indeed, have a broken door latch. If the latch is not able to lock successfully, it will not go into any wash cycle and will exhibit the symptoms you are describing. The door was designed to be closed gently, not slammed or forced. To replace, you will need to do the following: 1. Unplug the machine. 2. Remove the bottom kick plate. 3. Remove the rubber door boot from the around the door opening. There should be a wire hoop holding it into a groove with a small tension spring located at the bottom of the door opening. Feel around the rubber lip and locate the tension spring. Stretch this spring and pull the wire hoop from the groove. 4. Remove the rubber boot from the outer seal and push towards the inside of the wash tub. This will give you access to the inside of the machine casing. 5. The door latch is located inside the casing on the right hand side. There are three screws holding it in from the outside and a wiring harness and retaining clip holding it from the inside. Use care when removing the wires from the old latch. The wires are small and can break. I hope this leads you in the right direction. Let me know if you need any further advice.
Posted on Jun 08, 2007
Plot ideas for a story?
My dear you have to come up with your own plot. If you are a writer, it will come.
Jan 04, 2017 | Books
Floor is wet after washer spins out when washing king size comforter
Check the door seal is in the correct position and is not cracked or porous
Nov 26, 2013 | Kenmore Washing Machines
Samsung dryer tearing clothes
I would check to make sure there were not any sharp edges around the opening of the door, or on the door itself. If not then check the whole drum. I would guess there is something the fabric is catching on somewhere, causing it to tear before it eventually comes loose.
Jan 27, 2013 | Samsung Dryers
Can the lg washers wm 1832 cw handle a twin sized comforter?
It depends on the thickness,content and weight of the comforter.
If you have to stuff it in, don't wash it in your machine..take it to a laundromat.
Or if it is down filled, take it to a dry cleaner.
If it is a cotton filled quilt it will get very heavy when wet and may damage your machine, so I would take one of those to the laundromat as well.
If it is a light weight polyester-filled comforter, twin size and fits easily in your machine with out stuffing it in, it is probably okay.
Dec 20, 2010 | LG Washing Machines
Kenmore series 80 top loader washing machine 11029852991. When turned on spin cycle, makes a loud grinding kind of noise. I believe unit may have been overloaded with three kingsized bedsheets &...
unless some thing inside the washer is broken i would say the drum bearings have started to wear out badly,,,my washer will easly take 3 king size bed sheets and covers,,,that not a lot realy,,,how old is your unit? and how many washes has it done,,,years old and 1000's of washes?
Jul 16, 2010 | Kenmore Washing Machines
King down comforter
I tried washing a queen size comforter in my washer and blew the boot out of it. 250.00 repair bill. Go to laundymat!
Sep 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
367 people viewed this question
Sal De
Marvin
Marvin
jimorris77
