Question about Samsung Digimax 360 Digital Camera
POWER GOES OFF , AFTER PRESSING POWER ON
Dear Sir, Samsung Digimax 360 Digital Camera , put new battery Press power on Indication comes " LOW Battery " and power goes off What is the problem, and what the solution Best regards Khalid
I have a second of two 530 models. The first was replaced under warranty as the battery low came on with fresh AA batteries, but would work OK with the more expensive CRV3s. No change with the brand new replacement. I just use the CRV3s. As a side note, both the store I bought it from and the local "Batteries Plus" store told me there was no charger available for the CRV3 batteries. They lied. Many are available cheap on a simple Google search. Hope this helps.
Posted on Sep 04, 2007
    Genius:
  • 2,985 Answers
Make sure the batteries are of good quality and very new. If the probelm persists then it will have to go to the repair shop
Posted on Jun 07, 2007
SOURCE:
Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Apr 15, 2009 | Samsung Digimax A6 Digital Camera
Need help
Mine does the same thing. It takes a few minutes to realize it has new batteries. lol. Keep trying, it will eventually come on.
Sep 09, 2008 | Samsung Digimax D53 Digital Camera
Samsung digimax s600 problem
it might be the battery take it out and put it back in. if that doesn't work then try a new battery. or it may be cheaper just to get a new camera.
May 19, 2008 | Samsung Digimax S600 Digital Camera
Camera problems
Turns out the brand new batteries I installed were dead.
Mar 18, 2008 | Samsung Digimax S500 Digital Camera
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Jan 11, 2008 | Samsung Digimax S630 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Batteries
Suggest this a camera fault- return to seller or contact the Samsung web site Tech support Team
Jun 25, 2007 | Samsung Digimax S700 Digital Camera
CAMARA SOFTWARE PROBLEM
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
Sep 19, 2006 | Samsung Digimax A7 Digital Camera
Samsung Digimax 360 Digital Camera Logo
125 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
