Sansui tv with dvd installed
How can i hook up a dvd recorder to the sansui tv that has a dvd installed in the tv.
I have installed the dvd recorder but cannot find the display on this tv to show it is connected
    New Friend:
  • 57 Answers
It could be on your first or last channel on the tv.
click through the channels on the tv itself not your cable box good luck I hope this helps....
Posted on Jan 11, 2009
How to hook up a dvd player to a sansui digital tv
Read the owner manual which should have hookup instructions for this or Google the model number of set or player for "manual" to try to locate owner manual for either or both.
May 30, 2012 | Sansui Televison & Video
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
How do I hook up the recorder
Hi....
Take the output of the Satellite box to the "In from antenna" or "in from cable" then out to TV from the VCR to the TV.
TV should either be on 3 or 4 depending on what the satellite box is set for
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
I have a sansui vhf6010 vcr. i need to hook it up to my cable dvr to copy a recording. how do i do this? thanks!
connect the cable from the tv to the "IN" of the vcr. then connect the "OUT" of the vcr to the tv. play the program on your tv and push record on the vcr. you have to watch what you're recording, but at least it will record.
Dec 30, 2008 | Sansui VHF6010 VHS VCR
SAN0901 Manual
again hope this helps!
i'll check back to see if you need more help
electech
Oct 22, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sansui vrdvd5000- need manual
Hi seemaile,
All my searches resulted to negative which leads me to believe that there no readily available user manual for the Sansui VR DVD5000.
Sorry.
May 26, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Low volume on playback
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
May 08, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
Mar 01, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
SANSUI 218 - 250gb DVD Recorder Black & White
Send it back under warranty -- needs new main board.
Rudolf
Oct 20, 2007 | Sansui VRDVD5000 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
