Question about Kenwood KDC-MP5032 CD Player
My stereo is flashing the work "PROTECT" across the front
I bought a stereo from my son's friend and it has worked great for the past four months, but today I was going down a really bad street and hit a huge pot hole, then the words "PROTECT" started flashing and the radio will not work at all. What do I need to do? I appreciate your help if you can. Thank you, Shank22
  • Anonymous May 08, 2009
    my deck is flashing the word PROTECT .. Yesterday i was driving around and it was fine. Today i went to start my car and it says protect. It is a kenwood kdc
  • 156 Answers
In a Kenwood deck, "PROTECT" usually means that one of the speaker output wires is shorted. The first thing to do is pull the deck and inspect the wiring at the back, making sure there aren't any pinched or exposed wires. If a speaker wire is pinched against the deck chassis, or bare wire is touching dash metal, it can cause your problem. If you don't see anything obvious, disconnect all speaker wires from the deck, then turn it on. If it still flashes "protect", then you have a defect in the unit. If not, then re-connect the speakers one at a time until you find the one that causes it to go into Protect mode. Usually if you don't find a pinched or shorted wire behind the radio, the problem can be found at the speaker itself. This is especially common if you've installed after-market speakers; if a speaker terminal connection has come loose and is now touching the speaker basket or mounting surface, it will shut down the deck.
Posted on Jun 07, 2007
  • chef gavin May 31, 2011
    MY CD PLAYER IS JUST CONNECTED TO THE LIVE AND THE EARTH BUT WHY IS IT NOT WORKING AS IT WAS WORKING YESTERDAY?
    New Friend:
  • 3 Answers
Simple fix: while the radio is on, take the face off and you will see a small hole in the plate the face attaches to, which usually says "reset". push a pin in the hole to reset the radio. Most of the time that will take it out of protect mode and radio will work. if it is still in protect mode, then do what tech says, test the wires.
Posted on Oct 27, 2014
Hi i have a 95 buick lesabre i bought from a friend everything works great sides the radio i have an after market stereo jvc model no kd-g320 not sure witch color the antenna wire would be car has a power...
Antennae wire and other wires for the stock stereo are listed below:
1995 Buick LeSabre Stock Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Feb 19, 2015 | 1995 Buick LeSabre
MY CAR'S AIR CONDITIONING ISN'T WORKING. MY SON
mcdevito75 here, either your son in law didn"t put in enough freon or the compressor is not working, Have your local shop check it out.
Jun 18, 2010 | 1998 Cadillac DeVille
How do i bypass the brake
Most wiring harnesses have a solid orage wire for illumination of the radio and also have an orange wire with a white stripe for dimming purposes. Most radios do not use this dimming feature. Connect the brake wire to this wire and your able to watch your movies whenever you want. All the wire is looking for is a signal. It cannot differentiate between a parking brake signal and a non-parking brake signal.
Oct 06, 2009 | XO Vision XO9013 Car DVD Player
Speakers not working--FM and CD player shows it is
dear friend-as you say the fuses are there to protect these devices,but sometimes things goes wrong.it appeares that the output channels on you stereo is blown,you will have to remove and have it checked.
Jul 22, 2009 | Hyundai Azera Cars & Trucks
52'' sony tv rear projection turns blue
it sounds like the blue crt is failing Pull the front off and turn the tv on
When it still has a good picture tap the blue crt
if it flashes blue with lines across the screen then you know it is a bad crt
It might not be worth fixing
Good luck
Jan 26, 2009 | Sony KP-57HW40 57" Rear Projection...
Sonyy w55 flash works but shot come really dark
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Aug 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Telephone ring tone
press flash on phone til you reach desired ring tone then pick up headset to set
Sep 26, 2007 | Innovage 1604007 Corded Phone
JVC HX-D7
I had a similar problem, and took it to an authorized repair shop(under warranty), the kept it six months, and JVC finally admitted there are solder connections with that model, and six months later, we got a new unit. I will buy Sony next time
Sep 16, 2007 | JVC HX-D7 Shelf System
Kenwood KDC-MP5032 CD Player Logo
5,267 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
