How many watts ?
Hi can you please tell me what wattage a SANYO CE32WN5-B TV uses thanks
  • jinty9 Jan 11, 2009
    thanks for that but we have already checked the back and there is no mention of the watts also no mention in the instruction book, somehow i think it is higher than what you are saying for a [ 32" ] tv thanks
  • 57 Answers
Maybe is 115 to 125 watts.but if want to see the true wattage of your unit ,look at back of your tv set then read the label the tv ,you'll find the true voltage and the wattage of your unit.
Posted on Jan 11, 2009
I have a Sanyo Microwave EM-2500T, serial number 508650448 and I need to know the maximum wattage of it please. It was given to us second hand 23 years ago and is still going strong!
Hi Alison!
Wow. That microwave certainly doesn't owe you anything. Nice work on 23 years.
While not able to come up with the exact specifications or owner's manual, I would guess that 850 to 1000 watts would be pretty close to the number for your unit, especially if it's running on a 15A breaker.
Sorry I couldn't have been of more help.
-Steve
Mar 31, 2015 | Sanyo Microwave Ovens
How can I find out how many watts my System Model DA238A-ABA 6450NX NA910 use in 1 hour? (compaq prisario)
Compaq Presario 6450NX Desktop PC?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpb11683&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=240121
Power Supply - 200 Watts
That is the supposed Maximum Wattage the computer will use per hour.
Variables come in to play, however;
1) Back when the computer was made, the Power Supply manufacturers were 'fudging' the real maximum rated Wattage.
True ratings were more like 60 to 70 percent, of what was actually stated.
Divide 200 by ten; take it times;
6 for 60 percent. 120 Watts
7 for 70 percent. 140 Watts
So, the Actual Maximum Rate Wattage, could be as little as 120 Watts, or a little more than a 100 Watt light bulb.
2) Second variable is what is the computer being used for?
Surfing the internet? About 100 Watts.
Playing an intensive game, (Yeah right. Not on that computer), or using an intensive program?
Then, you may be using the Maximum rated Wattage,
120 to 140 Watts.
So,........the hourly wattage rating, could be as low as 100 Watts per hour, or perhaps up to 120 to 140 watts per hour.
Also include the power used by the monitor.
If you do not have the specifications of the monitor, see if you can look them up online.
My HP 2009M uses 47 Watts, (2 Watts when in Sleep Mode),
http://www.newegg.com/Product/Product.aspx?Item=N82E16824176112
My other monitor I use (Dual monitors), is an RCA 26 inch HDTV,
(RCA L26HD31)
Uses 82 Watts,
http://reviews.cnet.com/flat-panel-tvs/rca-l26hd31/4507-6482_7-33346932.html
(And the power supply for my computer is 500 Watts.
Hmmm,............no wonder the little wheel spins so fast in my electric meter! lol!)
Add the two together to get a basic conclusion, of what Wattage per Hour your computer system is using.
Don't forget to include printer/scanner/fax machine/copier, WHEN being used.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 04, 2013 | Computers & Internet
What size of inverter would i need to run a fax machine
That depends... some use 35 watts and some can use up to 200 watts...
Look on the bottom of the machine and on the rating plate it should tell you what the max wattage is///then make sure you inverter is large enough to handle that number of watts...
heatman101
Sep 14, 2011 | Cobra 2500w Power Inverter
I have a kenmore refrig/freezer. Full load amp is 6.5 , 60 hz and 115 volts. I have a generator that will take 1100 watts with 1500 peak or surge watts. I heard that refrigerators use more electricity or...
The calulation of max wattage is going to be 750 watts at start up and be around 500 on normal running wattage after start up so a 1100 watt generator should be fine.
GENE
Sep 06, 2011 | Kenmore Refrigerators
I'm in Europe where the voltage is 220 instead of 110-120. I need a transformer to use the fan but was wondering what wattage is required.
Hi elinorkim...
To find out what wattage transformer to use you must do a little math.
Multiply Amps times Volts = Watts...this is the least amount of watts you want to use, the more the better...higher wattage will make the transformer run cooler and last longer.
Look on the side of your fan for a tag that has this information on it.
Please take time to rate me
Sep 04, 2011 | Holmes Products /FANS HT38R-U Tower...
What is the wattage requirement for the Sanyo SR 172W?
Although the information is not published by Sanyo I was able to find out that the fridge uses about 90 watts.
Jan 06, 2011 | Sanyo SR-172 Compact Refrigerator
N15232 motherboard wattage help
the power supply wattage rating is MAX wattage, not constant wattage. the power supply only outputs the amount of power that the rest of the computer calls for, and no more. if yor computer only needs 200 watts, that is all that will be sent from the power supply; even if it has a max rating of 600 watts, it will only send the amount of watts which your computer calls for.
May 08, 2010 | Computers & Internet
Wattage
The output power for model MA-780 was 700 watts, so I'd bet yours is either 600 or 700 watts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 02, 2008 | Goldstar MA-782M Microwave Oven
12 volts plug in for my TV
Sure. These are called power inverters. Here's a link to one that should work. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=422932&CatId=237 Make sure you look at the wattage rating of the electronics you wish to run on the inverter and make sure you don't exceed that wattage rating on the inverter. You can get larger inverters but they have to be usually hardwired into the battery system of your vehicle.
Jun 23, 2007 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
CT-27SX11E Panasonic
The Ohms are ok but the wattage should have been the same or higher.A 1.5 with only 5 watts is not sufficient.
Oct 31, 2006 | Panasonic CT2722H TV
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
