Question about John Deere Garden
How to remove the front wheel on a JD 345 lawn tractor?
  • 37 Answers
SOURCE: can not remove axle cover,
Hi, easy fix you have to pry the cover off. you can use a screw driver, or a pry bar.
Posted on Nov 23, 2008
  • 272 Answers
SOURCE: JD Lawn Tractor L130. will not start
They have an auto shutoff for low oil, start there check your fluids. If Ok check for spark. Try full throttle choke off in case it might be flooded. See if any of that works and let me know.
Posted on May 10, 2009
  • 376 Answers
SOURCE: how to remove rear wheel of lawn tractor
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
Posted on May 15, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
mowerman1857
  • 389 Answers
SOURCE: John Deere LA175 lawn tractor front wheel bushings
Remove the tire and wheel from the spindle. Take a long punch or similar item and reach in the center of the wheel hub where the spindle goes. Locate the space in between the inner and outer bushing and tap the edge of the old bushing until it comes out. Now go in from the other side and do the same with the other bushing. This one will be a little easier to do since you don't have to hunt for the center space. Put the new bushings back in the same way just be sure you drive them in STRAIGHT
Posted on Sep 18, 2009
How do you remove the front lens to clean out debris or remove the headlight assembly on a 2006 John Deere 125 riding lawn mower?
under the hood i believe there are small plastic tabs you can push on to remove the cover to clean. be care full as jd has brittle plastic parts.
Oct 24, 2016 | John Deere Garden
JD 345 pto will not turn on.
What you need are wiring diagrams, not schematics, and you will have to inquire directly to John Deere.
Jul 20, 2016 | John Deere Garden
How do I disconnect the seat safety switch and the RIO switch
Here you go - this is for informational and troubleshooting purposes only.
RIO SWITCH SAFETY Yahoo Video Search Results
To disable the seat safety switch on my JD 345, I disconnected it and shoved a paperclip between the leads.
Sep 23, 2015 | John Deere D140 48 in. 22 HP Hydrostatic...
My 2000 jd sabre lawn tractor, when you moving an push on brake clutch it will not stop.thanks
You probably have a broken linkage that is not allowing it to disengage look around on your full lace on your mower deck you may be able to drop the deck by removing some other clips and pins Jack the front of the tractor up in the air or suspended it from wench
Aug 07, 2014 | Garden
I have a J.D. 345 and i think the cam gear may be broken but not sure. I have compression coming from both spark plugs when cranking but the push rod that allows the fuel pump to function isn't moving .
Not sure about the JD 345 but in general if the fuel pump pushrod isn't moving, there's only one solution, I'm afraid, you'll have to partially strip the engine. Removing the rocker covers will enable you to see if the valve gear is operational. If it is it' s possibly the fuel pump cam or follower, if the valve gear isn't working then it's the cam drive, could be a broken belt or chain or a sprocket key has sheared. Good luck.
Oct 29, 2013 | John Deere Garden
I am working on cub cadet lawn tractor lt 1050. how do i remove and replace the rear axel?
Hello.
SOLUTION ON How to Remove Lawn Tractor Wheels.
Owning a lawn tractor to take care of the grass and yardwork is convenient until the tires need repairing. It is inevitable that sooneror later the tires will go flat and need replacing. You can replace the tiresonce you know how to remove the wheels on your lawn tractor. Unlike automotivewheels which have several lug nuts, the lawn tractor tire requires only theremoval of a retaining ring to release the wheel from the axle.Front Wheels
  • 1 Park the lawn tractor on a level surface. It is better to park the lawn tractor on the driveway or solid shop floor rather than the lawn. Place a floor jack under the front frame and jack the mower up until the front tires are six inches off of the ground.
  • 2 Place jack stands under the frame on each side of the jack and lower the jack until the frame is sitting on the jack stands. If the mower is on the lawn, place a piece of plywood under the jack stands to avoid sinking the jack stands into the lawn.
  • 3 Pop the axle cover off of the center of the wheel. You can pry the cover off with a small flathead screwdriver or grab the cover with a pair of pliers and twist the cover off of the axle.
  • 4 Pull the retaining ring from the axle with a pair of needle nose pliers. Grab the ring from the closed side and pull the ring straight from the side of the axle. If necessary, use a flathead screwdriver to aid in spreading the open part of the ring so the ring will slide off of the axle.
  • 5 Slide the two washers off of the axle and then pull the wheel off of the axle.
Toolsneeded to solve the problem below. Floor jack,Pair of jack stands ,Small flathead screwdriver ,Needle nosepliers ,Vice grips
THEN SOLUTION ON How to REPLACE Lawn Tractor Wheels.
Thanks
Sep 15, 2011 | Garden
Front tire leaks. How do I remove the wheel for
Pop the hub cap and remove retainer. You could install a new tube yourself if you didn't want to have the tubless tire repaired.
Jul 25, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Can't get front wheel off my john deere lawn tractor
Aug 22, 2009 | Garden
Garden Logo
406 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
